moving brake line
Old June 8th, 2009, 06:13 AM
oldjunk's Avatar
moving brake line
Hi Guys,
I pulled the old 350 from my 1972 Cutlass S to make way for the 455. I have tube headers I am going to use, and I have learned from this site that it is necessary to move the brake line that is attached to the frame on the driver's side to make room for the headers. My question: How have you guys done this? Can I simply make a bracket to move it to the top of the frame as opposed to the side?
Thanks ahead of time.
oldjunk is offline
Old June 8th, 2009, 06:21 AM
Originally Posted by oldjunk
Hi Guys,
If you are using an automatic, you can simply bolt the proportioning valve to the top of the frame rail using the holes intended for the clutch Z-bar bracket. I've been able to move the proportioning valve to this location with the lines still attached and not had to disconnect anything.
joe_padavano is offline
Del70
November 15th, 2013 02:24 PM
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
bgoble
December 6th, 2010 06:32 AM
crzyjef
July 25th, 2010 06:25 PM
1971 442 convert
Site Help
May 16th, 2010 10:24 AM
Quick Reply: moving brake line
