Cleaning tobacco tar from interior?
Any recommendations on how to clean the inter of a car that was smoked in heavily? One of our Jetfire's was smoked in and the interior is grungy from it. I have tried some things in areas but it is not working out well. The paint on the dash is a flat finish and I am not sure what to use. I know flat finishes are affected badly by many cleaners. I did try dish soap and water but had little affect.
The headliner is in perfect condition but has so much tobacco tar in it that I don't think it is possible to clean it. My interior is silver so the tar makes it look very grungy.
Any thoughts? Anything special made for something like this?
The thing I have found to work is a strong detergent, like Fantastik, Formula 409, Oil Eater, etc.
These will generally dissolve and remove the nicotine, but they may not remove all yellow staining, if it's the result of a reaction with the surface.
They are also very strong, and can take off or change the surface finish of some paints, especially if the paint has been chemically weakened by the greasy nicotine.
Also, the lettering on the inside surfaces of some gauges will be completely wiped away by these.
Try on inconspicuous areas, and then use cautiously if you like the effect, and rinse with lots of water.
X2. I haven't used it on a headliner but numerous times on the interior of rental properties. Walls that are the color of hot chocolate will dissolve into something like what they were when painted originally( it won't fill in the 3 inch holes in the walls they left though)..... Tedd
I've found citrus cleaner to work really well, From sticky sport wheels to greasy parts. 3m makes an aerosol that I used on the sport wheel. I use the one gallon concentrate for undercarriage cleaning.
Tough to get out the smell. Ozone seems to help remove it. Or Ultra violet light. I put a UV system in my forced air furnace. Seems to remove a lot of odours. When I bought my house 30 years ago the owners were heavy, heavy smokers. You could literally see every stud in the wall from the ghost outlines of the nicotine. I tried everything to clean it but the smell remained. I ended up ripping out all the drywall and replacing it. I hate nicotine smell.
Are the seats and door panels vinyl. If so I have had good luck with Goop Hand cleaner (that comes in a small Plastic tub..) We had a contract to clean car and trucks for a locally owned carbon plant and it worked well on Vinyl Upholstery as well as the painted interiors of the older trucks. As for the headliners I would try a spot with mild soap and water then Blot out the dampness with Adult Diapers. Larry
I am sold on using Goop for vinyl seats now. Not sure I would try it on seats that are still in the car but it is worth taking the seats out if you want them real clean anyway. Thanks for the post.
jensenracing77
January 25th, 2014 06:55 AM
