Correct Mounting Engine Mounts
Old November 18th, 2011, 06:08 PM
Pacecar's Avatar
I'm fairly certain the engine mounts on my frame were never removed but I want to double check. Are the mounts supposed to be nutted from the top of the frame ? So the bolts go up thru the frame and then nutted ?
Pacecar is offline
Old November 28th, 2011, 05:37 AM
Indy_68_S's Avatar
Don't know what car you have, but my '68 Cutlass 350 had the mounts with nuts on top (bolts up thru frame from bottom) from the factory...
Indy_68_S is offline
Old November 28th, 2011, 09:40 AM
Pacecar's Avatar
Thanks for the help. I bouht a chassis service manual and it shows them mounted that way
Pacecar is offline
joesw31
May 31st, 2015 04:17 PM
dfire25
August 26th, 2013 08:04 AM
JCMC64
January 8th, 2013 09:21 AM
Nasty455
March 20th, 2012 04:57 PM
flatoz
March 15th, 2009 02:03 PM
Quick Reply: Correct Mounting Engine Mounts
