Correct Alternator Mounting Barkers?
Old August 25th, 2013, 08:12 PM
"Trying to fix her right"
dfire25's Avatar
Am I missing something (see pics)? The bottom part of the alternator is supported my an obvious non-stock turnbuckle. It works, but what is the correct way? I have another bracket (see last pic) that I'm planning on using, but I've seen it with or without a back supporting bracket. Do I need the back bracket? By the way, I'm going to be using these brackets on my new 455.
Thanks,
Dave
dfire25 is offline
Old August 26th, 2013, 05:38 AM
2blu442's Avatar
The first one needs a piece that's kinda triangle shaped. The second one is missing the H shaped piece. I know there's some old posts with pictures, if you have time try the search option with my name to see what comes up. The factory thought they were needed, I've never run an engine without them. But think it may vibrate too much and eventually break something without the support.
Both of these are common brackets. I've got extras of them both and know several other members here do too. I'd encourage you to decide which one to run with and create a parts wanted thread with your location and see what gets offered.
John
2blu442 is offline
Old August 26th, 2013, 05:52 AM
72 Olds CS
RetroRanger's Avatar
Can't tell for sure but it looks like the PS bracket is missing the spacer where it mounts to the WP as well
RetroRanger is offline
Old August 26th, 2013, 08:00 AM
dfire25's Avatar
No it's there, two 3/4" nuts! I'm going to have to make something up to replace them.
dfire25 is offline
Old August 26th, 2013, 08:04 AM
dfire25's Avatar
John
Thanks John. I'll probably go with the second one. I'll have to search out a "H" bracket then.
dfire25 is offline
442mark
September 30th, 2017 01:06 PM
chip-powell
September 5th, 2014 03:58 PM
Nasty455
September 14th, 2012 07:16 PM
Pacecar
November 28th, 2011 09:40 AM
daddyjws
February 3rd, 2005 01:44 AM
Quick Reply: Correct Alternator Mounting Barkers?
