help with 1968 cutlass core support bushings
Old June 24th, 2023, 11:25 AM
68glorydays's Avatar
I am having problems with the way the core support bushings go on, on my 1968 cutlass radiator. Its been a long time since I took them off and cant find any reference picks or information that will
help in guiding them back on correctly. First off, I do not know why my radiator support has slots instead of round holes that the new correct olds bushings fit into. My 1968 cutlass service manual
only shows how they go on 54 through 86 series is it the same for the cutlass?
is the 2nd pick correct in the way it goes together?
68glorydays is offline
Old June 24th, 2023, 11:36 AM
I see i forgot to mention the shim that sits on top of the car frame and lock washer at the bottom of bolt
Old June 24th, 2023, 11:47 AM
The diagram is in the PIM, section 11, page 140. The boss on the square bushing doesn't go into the core support, it goes into the frame hole. The round bushing slides over it from the underside of the frame. The core support just sits on top of the square bushing. The slots are for adjustment.
joe_padavano is online now
Old June 26th, 2023, 01:13 PM
thank you so much. the diagram is a big help. So do i need that nut spring? i do not have that and didn't get one with the new bushings.
Bee Saint Louis
June 4th, 2023 06:41 AM
71oldscutty
January 7th, 2021 07:19 AM
a-merry-can
March 19th, 2020 05:47 AM
smcfall
March 22nd, 2017 05:15 PM
Resistanc3
October 23rd, 2011 09:20 AM
Quick Reply: help with 1968 cutlass core support bushings
