Identifying frame swap
Hi, i bought a 67’ Cutlass supreme project car and it’s papers say the frame was swapped with that of a Buick but there is no more info and no codes on the frame to check. Do any of you have an idea as to what Buick would be most likely?
and also why it was swapped?
The frame will be stamped with the VIN number of the donor car in at least two places on one of the side rails of the frame.
It may be on the top of the rail, making it impossible to read without raising the body.
If you can find it, it can be de-coded to reveal the make and model involved.
buick frame
most likely to fit would be buick skylark, maybe because original frame was rusted bad.
https://classicoldsmobile.com/forums...racing-178545/
