Installing a new Windshield
Old December 22nd, 2014, 09:28 PM
RandyS's Avatar
I will be installing a new windshield in my 66 project and looking for advice. What do most of you use to seal the window in place? Butyl tape?
RandyS is offline
Old December 23rd, 2014, 07:21 AM
I've used the butyl tape on a number of cars in the past with no problems, but I think I'm going to try the urethane next time, as many folks seem to prefer it.
joe_padavano is online now
Old December 23rd, 2014, 09:29 AM
RandyS's Avatar
Does the urethane come in a canister like caulk? I have heard that the newer glass is thinner than the older stuff. How do you adjust the depth of the glass using the urethane?
RandyS is offline
Old December 23rd, 2014, 09:33 AM
Yes. The Fisher Body Manual shows you how to cut the tip to shape the bead properly.
Old December 23rd, 2014, 09:35 AM
RandyS's Avatar
Does it also show how to set the depth of the glass?
RandyS is offline
Old December 23rd, 2014, 10:09 AM
Octania's Avatar
That's one thing you might do well to have a professional come and take care of.
Low cost, great benefit.
Octania is offline
Old December 23rd, 2014, 10:45 AM
steverw's Avatar
You can use short segments of the butyl to keep the glass at proper height, perhaps using a little urethane under and over the butyl. Also use the setting blocks that come with the butyl tape to keep the glass raised correctly. Sometimes its difficult to get a good seal with butyl, everything needs to be really warm so its squishy enough to press the glass down into it. If its too cold its hard to press the glass uniformly around to get a complete seal. However you can then come back with the urethane and seal again after the butyl is in. Just try to keep the urethane OUT of your trim clips, once it hardens its hell to get it out and quite possibly your trim will not go in to the clip enough to lock in. Or wait to install the trim clips but be sure to leave room for them/ trim the urethane to allow room to install them after it sets up. I dont know its pretty tough stuff once it hardens.
I used the urethane to seal the front and rear of my intake manifold, I havnt tested it yet but it seems it should be ok. It cant be any worse than the rubber seals that keep squeezing out.
Steve
steverw is offline
Old December 23rd, 2014, 11:43 AM
Agreed. For $155 total price the glass company came out and installed the windshield in my driveway.
Fun71 is offline
Old December 23rd, 2014, 02:17 PM
RandyS's Avatar
That was for the Windshield and installation? Wow! How recently?
RandyS is offline
Old December 23rd, 2014, 02:41 PM
RROLDSX's Avatar
I have a fellow lined up to install both my front and rear for $160 (glass not included).
My concern is quality though. I've heard the installer should create a dam with thin foam tape like 1/2" around the bead in order to stop the smearing and showing up inside the trim edge. Does anyone know the exact details on this process?
RROLDSX is offline
Old December 23rd, 2014, 03:47 PM
I've always had a professional install mine. The caulk is ok but if you use too much it tends ooze out the trim in our Texas sun.
oldcutlass is online now
Old December 23rd, 2014, 06:41 PM
RROLDSX's Avatar
Therefore the requirement for a foam dam. I believe the installer is supposed to temporarily position the glass, trace around it with a marker, remove the glass, then apply a quarter inch foam sticky strip approximately 1/2" (I am uncertain on the exact width) inside the trace line then apply the caulking. The dam prevents the smearing (due to heat or whatever) that can be seen through the glass. I sound like I know the exact procedure but I don't and would appreciate any experts that know for certain.
RROLDSX is offline
Old December 23rd, 2014, 09:44 PM
70Post's Avatar
If you want the urethane method then LET A PRO DO IT.
Foam dams are typically used on urethane install jobs but it's not very common.....most places just lay down the bead and set down the glass.
Butyl roll is more "user friendly" for the DIY'er.....no special chaulk guns required, less of a potential mess, etc.
If you need some butyl tape I have two brand new rolls of 3M windshield butyl I got this summer (3M Windo-Weld Ribbon Sealer)...one is 5/16" and the other is 3/8". New in the box and both include setting blocks.
Will let these go very reasonably - $10 each + shipping.
70Post is offline
Old December 23rd, 2014, 10:03 PM
costpenn's Avatar
Patton, I'll take them if the OP passes.
costpenn is offline
Old December 24th, 2014, 06:32 AM
RandyS's Avatar
PM sent.
RandyS is offline
Old December 24th, 2014, 07:50 PM
Mr Nick's Avatar
I had the local Gerber Collision and Glass come out and do my windshield in the driveway this summer, I believe it was around $150 installed.
When I set the appointment, I specifically requested an experienced technician who knew how to do an old car properly. When the guy showed up, first thing he said was "I'm an old fart, I've been doing this a long time and I'll get it done right." The job is great, with no excessive urethane oozing out. I'm very happy.
Mr Nick is offline
Old December 25th, 2014, 06:58 AM
major noob
billmerbach's Avatar
I don't mean to brag but I installed mine 6 months ago with the urethane no problem and its still holding strong knock on wood lol
billmerbach is offline
rcdynamic88
June 14th, 2014 06:55 AM
fv64olds98
Body work
March 12th, 2013 04:50 PM
Brujay
December 2nd, 2012 04:10 PM
Brujay
November 6th, 2012 04:28 AM
American Lead
Body work
April 1st, 2009 04:41 AM
Quick Reply: Installing a new Windshield
