Lower control arms
Old January 14th, 2010, 12:57 AM
panos's Avatar
Lower control arms
When i was underneeth the car to check a nr.at my rear axle i noticed that the right lower control-arm,well lets say it doesnt look straight anymore.Now i am thinking to buy the Lakewood traction bars http://www.jegs.com/i/Lakewood/620/2...oductId=744077 does those eliminate the need of the lower control-arms or do they still have to be used?
Panos.
panos is offline
Old January 14th, 2010, 01:12 AM
Registered
Bluevista's Avatar
Panos.
You still need the lower control arms to be in place.
Check out the instructions for 20188.
http://www.lakewood-industries.com/I...aspx?BrandID=5
Burning some rubber and getting on it a little hard??
I would go with boxed stock or aftermarket type lower control arms.
They can be found all over the place.
If you go with boxed stock type you can add a rear swaybar, maybe some of the others too.
http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?storeId=10001&catalogId=10002&lan gId=-1&N=0&Ntk=all&Nty=1&D=boxed+lower+control+arms&Jna r=0&Ne=2%2B3%2B1147708&Ntx=mode%2Bmatchallpartial& Dx=mode%2Bmatchallpartial&Ntt=boxed+lower+control+ arms
Bluevista is offline
Old January 14th, 2010, 01:18 AM
panos's Avatar
What me noooo!
Found those:http://www.jegs.com/i/Jegster/550/41...oductId=753171
What do u think would they fit with the traction-bars?
panos is offline
Old January 14th, 2010, 01:19 AM
Eightupman's Avatar
Man, there are oldsmobiles all over Sweden. Sweet. I'll see if I can get you some contact info for a guy on another Olds website that may have some information as to what he is doing with his Cutlass.
Eightupman is offline
Old January 14th, 2010, 01:22 AM
panos's Avatar
Ok sounds good! I have to reinforce it a little before the 455 is in place
panos is offline
Old January 14th, 2010, 07:59 AM
Panos.
All those traction bars do is limit the motion of the rear suspension under acceleration by binding up the suspension. Not ideal and a PITA on the street. They do have an adjustable upper link so you can back off the adjustment when not at the track. In my opinion, you'd be better off getting Dick Miller's rear suspension setup.
joe_padavano is online now
tim72
Drivetrain/Differentials
May 25th, 2009 08:24 AM
hamm36
Suspension & Handling
May 23rd, 2009 09:55 AM
RATCHETMASTER
Brakes/Hydraulic Systems
January 29th, 2009 07:45 AM
red61
December 2nd, 2008 08:29 PM
Quick Reply: Lower control arms
