Off-the-shelf rear coil springs
Okay, it's spring time!
I am interested in getting some off-the-shelf rear springs for my 72 Cutlass to replace the old originals.
I am upgrading to the stock firm-ride setup.
The current Gabrielle Hijacker shocks will be replace with Bilsteins.
The boxed control arms and sway bar will be added.
Ride height needs to remain at factory specs.
I have heard some positive comments on Moog.
I noticed many here use the Moog CC501 coils, which are variable rate.
The alternate is the Moog 5413 heavy duty constant rate.
--If any of you used these, please comment on them!
Is variable rate a good advantage? Is the HD ones too firm?
I notice Rockauto also has AC Delco springs also. I am assuming these are newly made, but are they really built to the same specs as the originals?
Heavy duty constant rate is part # 45H2013
They are a bit costly, also.
--Anyone used them??
I am aware of Fusick's custom made springs, but not sure if i want to shell out the high price when Moogs might work well also.
Richard, are you using Eibachs on the rear??
RetroRanger
February 25th, 2014 05:04 PM
stlbluesbrother
Paint
September 6th, 2011 10:34 AM
