1986 tach gauges dashboard
Old May 7th, 2007, 04:59 PM
slipbakka's Avatar
Post 1986 tach gauges dashboard
I have a 1987 cutlass 2 door with the standard dash board.I just brought a cutlass dash with the rally gauges tach,water temp.oil pressure and volt meter.i need to know will this tach dash hook up easy with just the plugs or do i have to modify the plugs.the tach dash came from a 1986 2 door cutlass can somebody please help me.i hope i didnt waste my money on this tach dash.
slipbakka is offline
Old May 8th, 2007, 03:21 AM
Jim's rare 80
Jim's rare 80's Avatar
Gauges.
Hey. Installing proper gauges is never a waste. The cluster itself should be a straight "plug-n-play". Just make sure you install the proper sensors in your engine first. The sensors for the idiot lights are not the same. In future, you may want to post electrical questions in the "electrical" area on this forum. You will probably get mare replies as well. Best of luck. Any other questions. Let us know. Jim.
Jim's rare 80 is offline
Beob
October 2nd, 2012 03:51 AM
terrapin
August 7th, 2012 06:25 PM
Olds luvr
February 1st, 2010 09:27 PM
citcapp
December 14th, 2009 11:10 AM
Gary C
September 17th, 2007 06:53 PM
Quick Reply: 1986 tach gauges dashboard
