Idle stop solenoid
Old July 4th, 2011, 09:47 PM
roomer's Avatar
Idle stop solenoid
I recently bought a '72 Supreme with a 350 4bbl motor. Car runs great on the road feels a little sluggish off idle. My question is should this car have an idle stop solenoid to help with maintaining idle speed under load. My car doesn't have one, there is a bracket for one however. It seems to run better off idle without the A/C being on. Thanks for any help.
roomer is offline
Old July 7th, 2011, 07:26 PM
Frank3's Avatar
I think the idle solenoid was actually an anti-diesle device . Wired to the acc post on the starter , it held the idle open for idle speed , and when key was turned off it de-energized and let the the throttle fall below run-on speed . So no knockity-knock for 2 minutes after you shut it off .
How ever I'm with you on this and am using mine to bump-up the idle by wiring it to the A/C clutch relay .
Frank3 is offline
Old July 8th, 2011, 05:37 PM
BlackGold's Avatar
Don't confuse a solenoid with a slow idle dashpot. The latter has no wire or electronics -- only a spring and internal damper to keep it from moving too fast. It was used to keep the throttle from slamming closed too quickly which can upset the mixture enough to stall the engine.
The usage of the dashpot changed over the years. Some applications that often used a dashpot were those with A/C and/or those with manual transmission. Automatic cars without A/C might not need the dash pot, since the engine is back-driven through the torque converter when you take your foot off the gas.
Sorry I don't have a specific answer for your '72 Supreme. But if there's a bracket and it looks original, then you can bet there used to be a dashpot or solenoid, depending on which was used in '72.
BlackGold is offline
Old July 8th, 2011, 06:58 PM
Actually, according the the chassis service manual, the idle solenoid is used as part of the low idle setting procedure if the car came equipped with the solenoid. reference: page 6M-37
In it's capacity as a solenoid, the idle is set while the car is running and the solenoid is energized. Once the key is turned to 'off', the power to the solenoid stops and it retracts - and prevents dieseling too.
Allan R is offline
Old July 10th, 2011, 02:20 AM
roomer's Avatar
Thanks for the responses guys. Any thoughts on improving slow speed drivability with the a/c on? Runs great w/out a/c but that's not an option during a Mississippi summer.
roomer is offline
Old July 11th, 2011, 06:36 AM
AZ442's Avatar
I installed an electric idle stop (pick and pull) on mine inline with the compressor. brings the idle back up with the AC on. Works great.
AZ442 is offline
Markwz11
November 5th, 2013 06:09 PM
73rocketship
July 6th, 2012 06:45 AM
viper771
November 12th, 2011 03:29 PM
68conv455
September 21st, 2009 10:48 AM
Chumley
April 11th, 2008 07:08 PM
Quick Reply: Idle stop solenoid
