Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
62 olds idle stop solenoid tube and vac lines
Old November 2nd, 2011, 07:19 PM
viper771's Avatar
Hey everone. Still chugging away on the car this week. By the time it is "running" again I will have all new fuel lines to go with the rebuilt fuel pump. While I was checking things out, I tugged on the vac line going into the idle stop solenoid and it came out... The previous owner just kind of shoved the vac tube in there. I am trying to find the metal tube that screws into the idle stop solenoid that the vac tube goes into. I checked at inlinetube.com but I didn't see one listed. I am not sure on the diameter or anything. I just need the car to sort of run correctly so I can put gas in it. I don't trust it to drive it ver far yet due to a very leaky carb.
I think the vac lines are set up "correctly" besides that. I wish the shop manuals went into better detail like the later versions. Any help would be great.
viper771 is offline
Old November 3rd, 2011, 12:12 AM
oldsmobum's Avatar
On my car some of the fittings were pipe thread, like 1/8", where others where standard bolt thread like 3/8 24. Upon determining that you should be able to pick up a fuel line fitting with a hose barb or something similar that you can thread into that. You can buy them at any auto parts store.
oldsmobum is offline
Old November 3rd, 2011, 12:36 AM
viper771's Avatar
Ok thats good to know. I can just take my idle stop in and see if they can fit something. Most of the time I go in there and ask for "old car stuff" they look at me like I am an alien
viper771 is offline
Old November 12th, 2011, 03:29 PM
viper771's Avatar
Picked up a brake line that worked out great!! Now I just need to adjust everything.
viper771 is offline
Markwz11
November 5th, 2013 06:09 PM
73rocketship
July 6th, 2012 06:45 AM
roomer
July 11th, 2011 06:36 AM
68conv455
September 21st, 2009 10:48 AM
Chumley
April 11th, 2008 07:08 PM
Quick Reply: 62 olds idle stop solenoid tube and vac lines
