Intake Line for transmission fluid on Radiator
Old September 17th, 2011, 05:03 PM
atkinsom's Avatar
My brother just checked the tranny fluid level and my car has way too much fluid. Anyway, we want to drain some of the fluid by disconnecting the intake line into the rad, slide a flex hose while the motor is running and use it to drain into a pan. Problem is he can't remember which line is the intake line and which one drains back to the tranny. There are 2 metal lines going into the rad one at the top and one on the bottom. Which one is the intake line that we can slide the flex hose over to drain after disconnecting?
Thanx guys for your help and willing to hear other suggestions that does not involve opening up the tranny pan
TH350 Transmission
350 2-bbl
1969 Cutlass S
atkinsom is offline
Old September 17th, 2011, 05:10 PM
jensenracing77's Avatar
the bottom line comes from the transmission and the top line goes back to the transmission. unhook the bottom line and hook the hose to it.
jensenracing77 is offline
Old September 18th, 2011, 11:05 AM
'87 Delta 88 Royale
rustyroger's Avatar
If you unhook either line fluid will come out, from the radiator or the line.
Dont pump too much out and run the transmission too low.
In my experience the output line goes to the top of the radiator btw.
Roger.
rustyroger is offline
Old September 18th, 2011, 11:12 AM
Junkman's Avatar
Remove the lower line, and place a pan under it, then loosen the upper line to allow some air into the reservoir. If you drain the reservoir on the radiator, you will be removing approximately 1 1/2 pints of fluid. Tighten the fittings and then run the car till the transmission is hot. Check fluid level, and adjust as necessary by removing additional fluid, or adding fluid. It is best if you use a tubing wrench on the fittings, since they are soft and easily distorted.
Junkman is offline
Old September 18th, 2011, 12:34 PM
Roger.
you may want to double check this. if it is hooked up right it will go from the transmission to the bottom of the cooler and out the top of the cooler and back to the transmission.
Old September 19th, 2011, 01:08 AM
'87 Delta 88 Royale
rustyroger's Avatar
Double checked it, and a few others - all go to the top of the radiator.
I dont think it matters much which way round they go, the principle is to exchange heat in the radiator tank, direction of flow doesn't really matter imo.
Downflow radiators have the trans cooling lines in the bottom tank and go across the tank.
I don't want to quarrel about this, just saying what I've found.
Roger.
Old September 19th, 2011, 04:14 PM
atkinsom's Avatar
Thank you gentlemen. You've given me some great help. Appreciate it. Cheers.
atkinsom is offline
Old September 19th, 2011, 07:26 PM
Just to nail the lid on this:
MDchanic is offline
Old September 21st, 2011, 12:04 AM
'87 Delta 88 Royale
rustyroger's Avatar
I guess I'll have to eat some humble pie now.
I assumed the top line on the trans was the outlet one, thanks Eric - I learned something new today.
Roger.
Old September 24th, 2011, 10:27 AM
mike's88's Avatar
Much easier and cleaner, is to get a small hand pump, stick the suction line in the filler tube, then pull extra fluid out this way. Something like this http://www.harborfreight.com/multi-u...ump-66418.html
mike's88 is offline
Old September 24th, 2011, 01:06 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I'm with mike on this one.
I'd stuff a clear rubber hose down the dipstick tube, and grab the shop vac.
J-(Chicago) is offline
Old September 24th, 2011, 01:38 PM
NorTown Olds's Avatar
Thumbs up
SAME here...cleaner/easier by far...the less I mess w/ those lines and their connections, the better! GOOD Luck and keep us posted. GREAT advice and help here as always....what a GREAT FORUM: I always learn more on here everyday than I do anywhere else!
NorTown Olds is offline
Old September 27th, 2011, 08:00 PM
atkinsom's Avatar
I was just about ready to go and loosen the bottom connection when I decided to check this thread again...cheap, simple and multi purpose. Ordered 1 right away. Thanx mate
atkinsom is offline
oldsguybry
December 8th, 2012 08:15 PM
navvet
September 4th, 2012 08:19 AM
meads
February 12th, 2012 10:17 PM
Pookster6
October 31st, 2011 11:52 AM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
Quick Reply: Intake Line for transmission fluid on Radiator
