Manifold leak?
Old October 5th, 2010, 11:57 AM
Runner
Joffroi's Avatar
Manifold leak?
So I'm getting the exhaust installed at a local Midas and I'm going from 2" to 2.5" pipes. I had the obvious holes everywhere in my old exhaust (hence the replacement) but they said I also had leaks in the manifolds. They said if I just get the exhaust put in place, I would just get carbon monoxide leaking there still and it would effect the sound of the exhaust.
How complicated is it to fix a leaking manifold? They said I would need new headers. Unfortunately, I don't know anything about this, which is why I'm coming to you guys again.
Hopefully after this adventure, I'll be an expert at this like I am on changing water pumps now (thanks to you guys).
Joffroi is offline
Old October 5th, 2010, 12:19 PM
Do you have headers or exhaust manifolds? Headers can wear with age and leak around the primary tubes and the flange. Exhaust manfiolds don't wear much with age. Unless you have a crack from overheating or a broken off bolt hole in your exhaust manifold it is probably still good.
Olds64 is offline
Old October 5th, 2010, 12:34 PM
Runner
Joffroi's Avatar
Midas mentioned both... I really wish I had a camera to take pics of underneath my car
Joffroi is offline
Old October 5th, 2010, 02:43 PM
These are headers:
http://www.summitracing.com/parts/SUM-G9139/
These are manifolds:
http://www.themotorcompany.com/Manifolds-p-1-c-112.html
Olds64 is offline
Old October 5th, 2010, 02:47 PM
bil
bil's Avatar
Nice manifolds! Anyone make them for the Olds smallblock? ---bil
bil is offline
Kirk455
April 11th, 2014 06:30 AM
waterzap
October 21st, 2013 02:36 PM
oldsca
May 21st, 2012 08:50 PM
KevinBN7
April 9th, 2011 04:17 AM
toneypenna
May 24th, 2009 07:08 PM
Quick Reply: Manifold leak?
