Master Cylinder Conversion
Old May 8th, 2023, 06:15 PM
rthuck's Avatar
I have a 1966 Cutlass with a single master cylinder and I would like to convert it to a dual reservoir. Is there a parts supplier that sells a kit to make the changeover or at least a list of the parts needed to do the job?
rthuck is offline
Old May 9th, 2023, 05:32 AM
If you want to convert to a dual chamber master cylinder I suggest getting an OE one off of a later model Cutlass. I'm not sure what parts you would need though. Master cylinder, vacuum booster and proportioning valve at the least.
Olds64 is offline
Old May 9th, 2023, 06:37 AM
It's not quite that easy. The pushrod between the booster and M/C is longer on the single circuit master cylinders and won't work if you try to simply bolt a 1967 M/C to a 1966 booster. Yes, you can swap the combined 1967 booster and M/C onto a 66 and avoid this problem, but again be aware that the 1964-66 booster is 9" and the 67-up booster is 11". This is why 1967 442s used a single notched valve cover on the driver's side. It's not an issue on a small block car. I'll also add that there is no proportioning valve used on the four wheel drum cars, just a distribution block that really only serves to house the differential pressure switch that illuminated the BRAKE light if you have a leak.
I like to use the 1962-66 Cadillac master cylinder, which is dual circuit but configured for the long pushrod on these cars. It bolts directly to the original booster with no mods required. RAYBESTOS MC36373, about $71 at RockAuto.
joe_padavano is offline
Old May 9th, 2023, 11:15 AM
Run to Rund's Avatar
If manual drum brakes, here is the original 1967 setup:
Run to Rund is offline
Old May 11th, 2023, 05:45 AM
rthuck's Avatar
I appreciate your responses and I'll look into it more. The car is 4 wheel drum with power brakes.
rthuck is offline
Old May 11th, 2023, 06:23 AM
Thanks for the explanation Joe.👍
Olds64 is offline
Old January 13th, 2024, 02:41 AM
Tri-Carb's Avatar
When you use a 67 manual dual master to replace a single manual master on a 66 442, will a 67 line complete the hook up? Does anyone sell the complete conversion kit?
Tri-Carb is offline
Old January 13th, 2024, 06:29 AM
Unless you are changing the power booster you can't use a 67 master cylinder on a 66. Go back and read post #3.
Old January 13th, 2024, 08:40 AM
Tri-Carb's Avatar
The 66 does not have power brakes so #3 is not applicable regarding my line or complete conversion question.
Tri-Carb is offline
Old January 13th, 2024, 08:45 AM
Then you're fine. A brake line kit for a 1967 with manual drum brakes will work, assuming you install the factory distribution block in the stock location.
Old January 13th, 2024, 08:58 AM
Tri-Carb's Avatar
Thanks. The 66 distribution block is in the factory location. Does a 67 use the same distribution block in the same location?
Tri-Carb is offline
Old January 13th, 2024, 09:07 AM
No, which is why I mentioned it.
Old March 7th, 2024, 09:15 AM
Jeff Hiles's Avatar
i agree try to go oem bought a kit for my 64 from inline unfortunatly i let it sit for a year before installing,no warr got lucky the rod was the adjustable clevis the lines and block were difficult the masrer cylinder lid gasket was too big and wouldn't seal an old gm lid worked better i still carry brake fluid very disappointed
Jeff Hiles is offline
Hdhomer1969
Brakes/Hydraulic Systems
March 19th, 2022 01:46 PM
Sleepybeaver
November 7th, 2016 12:29 PM
ilandtime
March 10th, 2014 09:25 PM
kds 69 442
October 23rd, 2013 02:40 PM
Mr Shifty Sidney
June 12th, 2013 12:06 AM
Quick Reply: Master Cylinder Conversion
