Starter
Old June 12th, 2015, 06:09 PM
gtaa9's Avatar
Starter
I have a friend that has a 1969 Olds Cutlass 350cid. The car has headers and he keeps going through starters. He ended up buying a small performance starter for the car...to keep it away from the header. The starter bolts up but the gear in the starter isn't even close to the flex plate when engaged. I appreciate any suggestions. Thanks
gtaa9 is offline
Old June 12th, 2015, 06:49 PM
Can you post a PN, make and model of the starter. Is his engine stock?
oldcutlass is online now
Old June 12th, 2015, 11:26 PM
Senior Moment Member
z11375ss's Avatar
X2, it sounds like the wrong application. I run one on my 455 and it works like magic. Every time.
z11375ss is offline
Old June 13th, 2015, 05:38 AM
gtaa9's Avatar
The engine is stock. The starter he bought is a universal one. He bought the starter through Amazon. The starter is from a company named Demotor. Any suggestions were he can get the correct high performance starter?
gtaa9 is offline
Old June 13th, 2015, 06:09 AM
Rallye469's Avatar
A lot of the Aftermarket starters are Pontiac/Olds and need to be clocked a certain way to have them fit either application.
Are there multiple holes where the motor mounts to the mounting block?
It was like this on my Jegs unit and power master.
-pete
Rallye469 is offline
Old June 13th, 2015, 06:47 AM
gtaa9's Avatar
-pete
Yes....we tried ever hole. The starter gear is no were near the flex plate. So what did you do in your situation?
gtaa9 is offline
Old June 13th, 2015, 07:14 AM
I like the Powermaster XS or mastertorque starters
http://www.summitracing.com/parts/pw...ake/oldsmobile
Old June 13th, 2015, 07:38 AM
Beer Connoisseur
70cutty's Avatar
I have a power master XS, fits perfect and works great. No need to clock the position or shim the starter.
70cutty is offline
Old June 13th, 2015, 11:37 AM
gtaa9's Avatar
Thanks for the info guys...I appreciate it.
gtaa9 is offline
Old July 15th, 2015, 06:56 PM
amphicar770's Avatar
I have a mastertorque. Put it in a while ago but it was pretty much plug and play. Works great.
amphicar770 is offline
Old July 15th, 2015, 11:43 PM
I have headers on my car and a factory style starter. No issues in 20+years of operation.
Fun71 is online now
Old July 16th, 2015, 11:24 AM
^^^This. I've never had a problem with a factory starter (NOT a Chinesium rebuilt starter) and headers.
Also, the mini starters that have multiple clocking holes in the mounting block, the pinion and starter shaft pivot around the center of the shaft, so changing clocking has no effect on pinion to ring gear clearance.
There is no "universal" mini-starter for an Olds motor. You need the correct one for an Olds/Pontiac. Shims will only put the pinon further away from the ring gear.
joe_padavano is online now
cutlassKing
March 30th, 2007 01:06 AM
bjtstarfire
December 3rd, 2006 02:38 PM
jerry d
April 18th, 2006 05:05 AM
Bens71442
January 3rd, 2006 03:33 PM
Lobo
June 29th, 2004 09:05 PM
Quick Reply: Starter
