1969 El Comino 12 bolt to 1969 Cutlass S. Swap
Old February 12th, 2008, 06:36 AM
mcutlass1969's Avatar
Smile 1969 El Comino 12 bolt to 1969 Cutlass S. Swap
I have located a 12 bolt posi rearend out of a 1969 El Comino and curious if it will match up to my 1969 Cutlass S. I am looking for information if this would be a possible conversion? I also need to know what I am looking for in measurements to make sure I am not getting scammed.
Thanks for your help.
Mike
mcutlass1969 is offline
Old February 12th, 2008, 08:59 AM
Mike
It's a bolt-in (in fact, Canadian-built Cutlii received Chevy 12-bolt axles from the factory). You may need a different driveshaft as the dimension from the pinion flange to the wheel centerline may be slightly different.
joe_padavano is offline
tnwheelgunner
Drivetrain/Differentials
March 10th, 2015 09:34 PM
yankees
June 13th, 2013 03:16 PM
monzaz
September 11th, 2012 08:27 PM
'69CutlassVert'
August 25th, 2011 07:19 AM
kayle
December 24th, 2007 06:03 AM
Quick Reply: 1969 El Comino 12 bolt to 1969 Cutlass S. Swap
