350 Olds Motor and 10 Bolt Rear End
I'm concerned about my rearend on my 85 Cutlass. I have a 350 motor and it's getting bored .30 over with the original heads shaved 10,000, 750 Holley Duel Feed Double Pump Carb and 292 Cam. My rearend is a 10 bolt 7.5 series. Does anyone else have similar components or comments that may ease my mind. I would like to put a mini spool in, so I can have positive traction. Any info is highly appreciated.
What are you plans for the car? A spool is a really bad idea on the street unless you never plan to turn a corner. If you do, get a good limited slip unit.
You might call carson auto wrecking (310) 835-7291 and ask about interchange ...
Better to use one of these: http://www.tomsdifferentials.com/catalog.asp?pg=40
Chevelle is an A body.
From post #2:
The rest of the post is well worth reading.
Norm
From post #2:
........ The A-body axle swaps are not well engineered in my opinion and require rear wheels with custom offset. By the time you're done buying the control arms, the A-body axle, and the custom wheels, you might as well have just bought the right axle to start with .........
Norm
67442nut
January 6th, 2017 09:09 AM
350TurBRO
September 12th, 2014 11:52 AM
RALLYE KID
December 20th, 2013 11:58 PM
Aceshigh
June 10th, 2010 08:16 PM
