Advice on 4spd Transmissions
Hey guys, sorry for bringing such a small detail up, I dont know where to look for this information so i was hoping one of you would know. Im going to convert my 69 cutlass 4-door over to a 4spd. I highly douby i will have the money to buy an actual 4spd from a 69 cutlass, so i was wondering what transmissions would cross over ? i was thinking about just swapping out the rear end with just a GM 12 bolt or something to make up for the rear gears, and if i have to make an adapter plate to bolt the transmission up. I dont think it would hurt anything, because i need to get the special pilot bearing in order to get the 4spd to bolt up. So what transmissions could i use ? and if you have any leads on ones in good condition that would be great. thanks again
Ok looking back on that it didnt really make sense, let me rephrase, i want to use an M20 in my 4sp swap, almost all the muscle cars came with M20's lol. So what splines do i need on the input shaft and the output shaft ? And if i cant find an oldsmobile bellhousing to put on it, what would work with mild modification ? thanks
Last edited by The_Jeremiah; January 23rd, 2008 at 08:58 PM. Reason: Poor Explanation LOL
There are three different Muncie transmissions - M20, M21, and M22. Prices on all have been driven through the roof by restorers. An option is a Borg Warner T10.
hmm
Ok i think the borg warner T10 is a good candidate to go with, but i was wondering if i could shove a saginaw under there ? they look almost identical. What do you guys think ? also i cant find anywhere the splines i need on each end. what do you guys think ? thanks again
68conv455
January 12th, 2009 06:58 PM
