Still No Clarification
O.K. I ordered a drive shaft today from the parts place and now again I am not sure if I ordered the right one. Why is this so difficult? It is a 1969 olds 442 W30 4 speed there shouldn't be 14 choices of u joints and yokes! I need to know is it a 1310 or a 1330 front and rear with clips inside or out? There has to be someone out there that can answer that so I can order what I need.
It is neither. The Olds used the 3R u-joints in the front & back.They make transmission yokes for all types of u-joints,and they make the 3R. That driveshaft would also be the same length as a 68-70 with TH350 and the O-axle because the small output 4-spds have the same length as the TH350.
delta881972
May 16th, 2013 08:02 AM
