Type O Rear Differential Swap
Old December 15th, 2013, 12:33 AM
HitTheHole's Avatar
Is this all I need to convert my 1970 Olds non-posi Type O rear end to a posi?http://www.billsgear.co/traction-dev...pline-12-bolt/
HitTheHole is offline
Old December 15th, 2013, 06:50 AM
Justin
oldstata's Avatar
That's pricy I would check with 507olds or monzaz I am sure they can help you out
oldstata is offline
Old December 15th, 2013, 07:36 AM
oldsmobiledave's Avatar
or
$65.00 cheaper @ Supercars Unlimited.
http://www.supercarsunlimited.com/12...iers-i275.aspx
or you can contact CO members on here to buy direct from them @ better prices.
oldsmobiledave is offline
Old December 15th, 2013, 08:16 AM
Octania's Avatar
Installation may require additional parts, tools, and expertise.
Mightaswell the bearings, right?
No actual-part photo and no product reviews yet rubs me the wrong way.
Octania is offline
Old December 15th, 2013, 10:38 AM
HitTheHole's Avatar
Thank you for pointing out a lower price but I'm most concerned with getting the correct and complete parts. Will I need other parts in addition to the carrier? Does it make sense to replace other parts when doing a swap?
Old December 15th, 2013, 10:40 AM
Justin
oldstata's Avatar
Axle bearings and seals monzaz does this everyday if memory serves me he quoted me 600 for posi bearings and rebuild kit
All the posi unit is for these is a ford 8.8 machined to fit in olds housing
oldstata is offline
Old December 15th, 2013, 12:15 PM
more
DING DING DING...We have a winner. This is EXACTLY what I did when I converted the original 3.23 open in my 1969 Olds 442 to a posi. Many others on here have done the same. Deal with other members of this forum & you will come out ahead. Jim is excellent to deal with & prices are fair.
That said I have done business with Supercars & always was satisfied with the service & parts received. I got a 3.42 crown & pinion from them in June of 2012 (I think it must have been the last one in captivity).
Old December 15th, 2013, 01:24 PM
Originally Posted by HitTheHole
Is this all I need to convert my 1970 Olds non-posi Type O rear end to a posi? http://www.billsgear.co/traction-dev...pline-12-bolt/
If you currently have 3.08 to 3.23 gears, then this carrier will work. That ad doesn't say if the carrier has new bearings installed, so if it doesn't you will need new carrier bearings and get them pressed onto the carrier. I would also replace the axle bearings and seals when it's apart since they will be readily accessible during the carrier swap.
Fun71 is online now
Old December 15th, 2013, 05:57 PM
Hookers under Hood
76olds's Avatar
X3 Jim ( monzaz ) is excellent to deal with, I just did a deal with Him, not only are his prices awesome, he also lowered the price some because the shipping to my place in Canada was up there. New Eaton Posi unit , Eaton HD install kit , 3:42 pinion and gears, Bearings and seals.
76olds is offline
Old December 17th, 2013, 05:51 AM
monzaz's Avatar
Posi and stuff for the 12 bolt O
WOW 664.00 MAn that is A LOT! I have the same unit on Ebay for 479.00
Eaton type.
They are charging too much for the machine work for sure. Jim
PM Will help you out.
monzaz is offline
Old December 20th, 2013, 05:16 AM
507OLDS's Avatar
The posi unit that Jim sells is NO different than the ones that SuperCars sell,or Bill's Gears sell,or I sell. They are all remachined/modified 8.8" Ford units.
Nobody makes a new casting for the O-axle. That is also why the unit has two sets of ring gear holes.The other set was the Ford pattern.
507OLDS is offline
Old December 22nd, 2013, 07:10 AM
monzaz's Avatar
Differences
wELL THERE ARE SOME DIFFERENCES- They sell the trac lock (S Spring) mine is based off the Eaton unit which i consider better. That is the NEW units I sell. Jim
I normally keep a verity of reconditioned and new and can even do true trac posi units BUT with the stagnate supply of GEARS! I have been not producing as many. Jim
monzaz is offline
Old August 7th, 2014, 05:41 PM
cdoering's Avatar
Looking for a 3:23 posi for my 70 442 W30. Call me to discuss price and what is included
Chris 314-495-1700
cdoering is offline
Old August 7th, 2014, 05:47 PM
Beer Connoisseur
70cutty's Avatar
Chris just call Jim, you can find his number on jdrace.com
70cutty is offline
rcorrigan5
May 3rd, 2015 10:15 AM
Otto Skorzeny
Drivetrain/Differentials
March 13th, 2014 07:16 PM
L77F85
16
November 29th, 2013 06:19 AM
Samson
April 9th, 2009 05:39 AM
Flamed67
October 20th, 2008 09:40 AM
Quick Reply: Type O Rear Differential Swap
