Where to put jackstands for when changing differential fluid?
Old October 21st, 2013, 11:51 AM
yeahbuddy's Avatar
Jackstands when changing differential fluid?
68 Cutlass Supreme 4 door. Need to change the differential fluid and seems easy enough to do. I am wondering what is the absolute safest way to raise the rear end for enough room? I currently have Hi-Jacker air shocks in the rear with 275/60r15 wheels so it sits pretty high as it is. Where would be a good spot to put the jackstands and jack? Also best way to raise it?
yeahbuddy is offline
Old October 21st, 2013, 11:58 AM
stan 65 cutlass's Avatar
lift under the pumpkin, and put stands as far apart as you can, (near the tires)
stan 65 cutlass is offline
Old October 21st, 2013, 12:00 PM
yeahbuddy's Avatar
Can you please be more specific as far as 'near the tires' means
Old October 21st, 2013, 12:01 PM
Professur's Avatar
Under the axle tubes, just at the spring perches.
Professur is offline
Old October 21st, 2013, 12:02 PM
yeahbuddy's Avatar
The rear end will have all of its weight on the axle tubes and the jackstands?
Old October 21st, 2013, 12:03 PM
under the axle tubes close to the lower shock mounts, the further apart you space them the more stable the car will be. sometimes you cant get the stands to sit right beside the tires because the stand will hit somewhere.
Old October 21st, 2013, 12:05 PM
yip, axle tubes are strong, dont try this on a car with front wheel drive though, those rear axles arent too strong for lifting in the middle
Old October 21st, 2013, 12:07 PM
yeahbuddy's Avatar
Appreciate it.
Professur's Avatar
It already does ... why do you think the springs are attached there?
Old October 21st, 2013, 12:11 PM
Appreciate it.
you owe me a beer next time you see me
Old October 21st, 2013, 12:13 PM
yeahbuddy's Avatar
Old October 21st, 2013, 12:22 PM
yeahbuddy's Avatar
My rear end is high enough where I can crawl under and have access to all the bolts. Is it impractical to attempt to change the diff fluid without jacking the rear
Old October 21st, 2013, 12:52 PM
You can slide under and do it that way, or put the stands under the axle tubes, or the frame forward of the rear wheels.
oldcutlass is offline
Old October 21st, 2013, 01:37 PM
yeahbuddy's Avatar
Okay got it. One more question and I'll stop bothering you guys. For a 12-bolt gasket, my local OReilys only carries a FelPro "O-Type" gasket in a 12 bolt. Is this the correct version needed for my pumpkin? What is the best brand/weight oil to replace it with. Thank you
Old October 21st, 2013, 01:42 PM
Professur's Avatar
It's not an active gasket so anything will do ... even just a hoop cut out of cork. As for the oil, what does your factory manual say to use?
Old October 21st, 2013, 01:49 PM
For an open rear plain ol 90w will do.
Old October 22nd, 2013, 06:08 PM
yeahbuddy's Avatar
Well, thanks again guys I was able to easily knock it out today in a couple hours. Didn't even have to jack up the car I was able to get under fine and there was a lot of clearance for my torque wrench to get the bolts at 25 ft lbs. Took the opportunity to do a quick prime and paint. Only needed around little under 2 liters of NAPA 80-90 SAE gear oil.
Old October 22nd, 2013, 06:37 PM
I've changed the oil in three differentials this week, so I'm sorry I missed this thread.
I would add that I much prefer jacking up the car (not the rear end) in order to do this.
Jack up from both sides of the frame (although one is usually enough), just ahead of the rear fenders. This will raise the car (frame, floor, gas tank), but not the wheels or the rear, thus giving you better access to the differential without squirming and straining.
As far as cleaning, yes BrāKleen is great for this. It really gets a lot of stuff out, and, yes, it's okay to spray around in there if you want to (I generally spray only the "floor" of the differential, to clear out any debris that may be resting on the bottom,and on the gasket surfaces. It softens old RTV pretty well, too).
Also, most, if not all modern vehicles with conventional rear ends have dispensed with gaskets and just use a smear of RTV to seal - put a film where the gasket would go (don't use the entire tube, like the PO of one of my cars appears to have done ), bolt it up, and leave it overnight before filling.
MDchanic is offline
Old October 22nd, 2013, 06:40 PM
Fill it to about 1/2 inch below the inspection plug. I usually put my index finger in the hole one digit and when you feel fluid its full.
Oh and by the way, now that you painted that cover all nice and neat...it's time to get the whole underside to look like that so it doesn't stick out.
Old October 22nd, 2013, 06:54 PM
yeahbuddy's Avatar
That O ring Felpro gasket worked perfect. Also put an even layer of gear oil ATV gasket maker on each side. It hasnt leaked yet. Dont think it will. I ended up just drawing out all the oil that was on the floor and wiped the inside and walls down with a clean rag. Didn't want to spray anything in there. Appreciate your post. Im sure many will find this thread helpful in the future.
Old October 22nd, 2013, 06:56 PM
yeahbuddy's Avatar
Maybe when I pull the gas tank I will have a better opportunity to get the sides.
I thought I needed 2.5 liters but at the end of the 2nd bottle it started overspilling back out the plug hole. I let it drip out until it stopped then I capped it. Might be right at the end of the plug hole.
Old October 22nd, 2013, 07:00 PM
Yeah, the exact level is really unimportant. Within half an inch one way or another is fine.
I usually just fill it till it comes out, then cap it quickly.
Some people like to use a bit less, to reduce seepage and make it neater to check the level later on.
In my case, if I'm touching it at all, it's because I'm changing it - Unless I see a puddle under the rear, I'm not checking the oil.
MDchanic is offline
yeahbuddy
January 3rd, 2014 10:08 AM
68oldscutlass
Drivetrain/Differentials
17
March 22nd, 2013 05:37 PM
Dant
August 10th, 2011 04:09 AM
Bottoms
September 29th, 2010 07:34 AM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
Quick Reply: Where to put jackstands for when changing differential fluid?
