1989 Oldsmobile Delta 88 Ignition Kill Switch Short
Old April 5th, 2006, 09:02 AM
mm89olds's Avatar
This car has an ignition kill switch where you need to turn the left turn signal on before starting the car.
Were these installed at the factory?
There is some sort of short now where you can see smoke coming from the center of the dashboard near the clock.
Where do I disconnect the kill switch – which color wires should the harness be?
mm89olds is offline
Old April 6th, 2006, 11:03 AM
jdorour's Avatar
I do not think this was a factory install.
I looked in my manual (AllData) and there is nothing that indicates this was a factory install.
Turn signal wires:
From the fuse to the turn Signal Flasher - Dark Blue
From the Flasher to the Switch - Purple
From the switch to the Left Side Front - Light Blue
From the Switch to the Right Side Front - Dark Blue
From the Switch to the Left Rear - Yellow
From the Switch to the Right Rear - Dark Green
jdorour is offline
Switch Blade Betties
September 3rd, 2013 09:25 AM
theoldsrocket
May 11th, 2011 01:14 PM
Rickman48
March 23rd, 2011 01:03 PM
New'n72
January 30th, 2009 01:42 AM
projectheaven
May 6th, 2008 06:45 PM
Quick Reply: 1989 Oldsmobile Delta 88 Ignition Kill Switch Short
