Timing and Spark Plug Gap for 350 engine
Old October 31st, 2007, 10:25 AM
ChrisM's Avatar
Hello all,
I recently converted the 350 engine in my '73 Delta 88 to a Pertronix electronic ignition. I need to set the timing and my repair manual says to see a sticker in the engine compartment, but the owner before me had removed all stickers in a repaint effort. Does anyone know what the proper timing setting is for my car? Also, I want to put a new set of spark plugs in, but I don't know what the gap should be set at?
Thank you all in advance,
Chris
ChrisM is offline
Old November 1st, 2007, 02:23 PM
kevinkpk's Avatar
Originally Posted by ChrisM
Hello all,
Chris
I can remember when electronic ignition systems came out in the 70's, plug gap for Gm's were .060". Timing my 455 w/distributor likes about 12 deg btdc, I'd play with that, AC R46R gaps at .035". The nonexsistant sticker may not do you any good with an electronic ignition unless it came with electronic ignition, then I am quite sure about the .060" plug gap.
kevinkpk is offline
bonesbmx
June 2nd, 2020 02:10 PM
Sarum
March 26th, 2015 09:14 PM
dallasite21
May 25th, 2012 09:07 PM
yeahbuddy
April 27th, 2012 10:45 AM
ChrisM
March 7th, 2009 08:07 PM
Quick Reply: Timing and Spark Plug Gap for 350 engine
