350 spark plug gap
Old September 15th, 2007, 11:30 AM
bonesbmx's Avatar
350 spark plug gap
hi whats the gap for a 350 olds?
thanks
bonesbmx is offline
Old September 15th, 2007, 12:55 PM
crazy'boutOlds's Avatar
Do you know what year motor?
crazy'boutOlds is offline
Old September 15th, 2007, 12:56 PM
Looks like most are 0.060
Old September 15th, 2007, 01:01 PM
bonesbmx's Avatar
gap
its a 1972 350 olds motor my hanes book doesnt say
bonesbmx is offline
Old September 15th, 2007, 01:46 PM
HEI or points?
Old September 15th, 2007, 01:49 PM
Have you tried asking your local auto parts store? They should be able to give you the correct gap.
Old September 15th, 2007, 01:52 PM
bonesbmx's Avatar
my parts store says 0.040 hei i belive. also when im shopping for headers what other cars are exact same fit. camero? firebird? are they the same size as the 442 big block?
thanks
bonesbmx is offline
Old September 16th, 2007, 03:20 PM
No 442 big block exist! You have a 350 in an A-body car. Like a Chevelle/ Malibu, Lemans/GTO, Skylark/GS. Thos would be some sismlar models
Old September 16th, 2007, 03:21 PM
Redog's Avatar
Points gap .032, HEI gap .045
Redog is offline
Old September 17th, 2007, 01:13 AM
Junior Member
88 coupe's Avatar
FSM should say '030" for the '72 engine.
FSM should say .045" for the '74 engine.
The extra .015" is to fire the lean mixtures in the emission controlled '74, and up, engines.
.032" will work fine in any, non emissions, application.
Norm
88 coupe is offline
Old September 17th, 2007, 03:57 AM
Huron's Avatar
thanks
.035" if you have points, .045" if you have HEI
Huron
Huron is offline
Old September 17th, 2007, 05:28 PM
bonesbmx's Avatar
Thumbs up
thanks guys
the help is great.
bonesbmx is offline
Old September 23rd, 2007, 11:12 PM
shaks 442 clone's Avatar
i was running .050 in my motor? but also i have hei and an msd 6a box so, that was ok right?
shaks 442 clone is offline
Old February 24th, 2016, 10:37 AM
Gearhead in training
Middian's Avatar
Points?
Huron
How would i tell if i have point or HEI?
sorry for my ignorance
Middian is offline
Old February 24th, 2016, 10:55 AM
Chevy budget Olds powered
coppercutlass's Avatar
wow this is an old thread but. Hei has a coil mounted directly on top of the distributor. Points usually had the old can style coil mounted else where.
coppercutlass is offline
Old February 24th, 2016, 11:18 AM
And the diameter of the distributor is larger on the HEI...
oldcutlass is online now
Old February 24th, 2016, 12:14 PM
Points on left, HEI on right.
Fun71 is online now
Old June 2nd, 2020, 01:47 PM
painterbrad's Avatar
Old thread similar problems
painterbrad is offline
Old June 2nd, 2020, 02:10 PM
Plug size and timing
I know this is an old thread but I’m in sort of the same situation. I have a 64 cutlass with a 330
4 barrel and the 442 cam. The car was a 290 HP engine so I’m guessing that it is the same as a 442 engine now with the 442 cam. It has
aftermarket harmonic balancer that was supposed to be for a 64 or 65, the problem is the timing marks are on the left side. So timing it has been a challenge to say the least.
I’VE been using a vacuum gauge to try and set it.car has Thornton exhaust manifolds with true duals and a pertronix ignition. The plugs are R45S. My problem is where to set the timing and should I go with R43S plugs? The carb is a stock one from an automatic and the car is now a 4 speed. Also should the plug gap be 35?
thanks Brad
yeahbuddy
April 27th, 2012 10:45 AM
ChrisM
March 7th, 2009 08:07 PM
boese1978
March 16th, 2008 03:50 PM
ChrisM
November 1st, 2007 02:23 PM
66starfire
January 3rd, 2007 10:31 AM
Quick Reply: 350 spark plug gap
