Spark Plug Gap
Old January 2nd, 2007, 10:36 AM
66starfire's Avatar
Spark Plug Gap
Got a 1970 Delta 88 455 Motor.
What should plug gap be? Im thinking around .35-.45 correct?
Anyone know for sure?
66starfire is offline
Old January 2nd, 2007, 11:18 AM
Past Administrator
Oldsguy's Avatar
.030 is what I always used, works fine. I think that is the official spec sheet value.
Oldsguy is offline
Old January 2nd, 2007, 11:58 AM
66starfire's Avatar
Ok thanks alot. Gunna go replace those 8 right now then.
Old January 3rd, 2007, 02:35 AM
66starfire's Avatar
just saying, was looking throuh an ac delco spark plug catalog, says that .045 is the gap..that seems a bit big, and .030 seems a TAD small, so Im going with .035 as a sorto middle ground. Hehe Ill se if it works.
Old January 3rd, 2007, 04:35 AM
Past Administrator
Oldsguy's Avatar
Was that for your vehicle/engine or a generic setting for the plug? .045 seems too large for standard points ignition, maybe ok for some HEI but.....
Oldsguy is offline
Old January 3rd, 2007, 07:32 AM
Tom Servo's Stunt Double
texasred's Avatar
Just spoke with my local Olds Guru (Dan Sarvis...President of the South Texas Oldsmobile Club, races an unported cast iron head QJetted 1970 442 into the 11s, and great QJet guy if you ever need work done) and he says .030 is the stock gap. If you are using an HEI, you might want to go .035, but not over that.
C.J.
texasred is offline
Old January 3rd, 2007, 10:31 AM
66starfire's Avatar
Ok good because Ive got an HEI distributor on it. Prolly should have mentioned that early, my mistake. Thanks for the helpful information guys.
bonesbmx
June 2nd, 2020 02:10 PM
ChrisM
March 7th, 2009 08:07 PM
Chumley
May 27th, 2008 08:25 PM
boese1978
March 16th, 2008 03:50 PM
ChrisM
November 1st, 2007 02:23 PM
Quick Reply: Spark Plug Gap
