1970 cutlass no power to ignition
Old March 21st, 2024, 02:55 PM
Bigstan78's Avatar
From time to time there is no power to the ignition switch when the key is turned and sometimes when the key is turned, the car just turns over but doesn't start after unplugging the battery and charging it. The car will start after a while it will continue to do the same thing it was doing before no power no start what you guys think it could be. Brand new neutral, safety switch brand new battery brand new ignition switch can't seem to figure it out.
Bigstan78 is offline
Old March 21st, 2024, 03:04 PM
Stock points or some other distributor?
The next time the car doesn't start, run a temporary jumper directly from the battery + terminal to the + terminal on the coil If it still doesn't start, the problem is in the coil or distributor. If it does, the problem is in the wiring.
joe_padavano is online now
Old March 21st, 2024, 03:14 PM
Bigstan78's Avatar
[QUOTE=joe_padavano;1560117]Stock points or some other distributor?
The next time the car doesn't start, run a temporary jumper directly from the battery + terminal to the + terminal on the coil If it still doesn't start, the problem is in the coil or distributor. If it does, the problem is in the wiring.[/QUOTE
MSD coil and distributor car does have aftermarket bog warner voltage regulator car has a generator not a alternator
Old March 21st, 2024, 03:24 PM
[QUOTE=Bigstan78;1560119]
Following along...interesting combination right there.
Vintage Chief is offline
Old March 21st, 2024, 03:32 PM
WHICH MSD coil and distributor? How is it wired? And no, you do not have a generator in a 1970 Oldsmobile. Please post photos. We have no way of knowing how the car is put together if it's been modified, nor do we know the quality of the work.
Mlunsford33
December 16th, 2022 01:01 PM
Dwilla
July 19th, 2022 11:22 PM
gnoto
Tech Editor's Desk
October 8th, 2019 06:14 AM
indy500
November 27th, 2018 02:41 PM
kaboom78
Alero
June 29th, 2010 07:41 PM
Quick Reply: 1970 cutlass no power to ignition
