Dash Bulbs
Old February 28th, 2024, 02:36 PM
Chuxter's Avatar
Dash Bulbs
Can I get replacement bulbs for my gauges on my 1970 Cutlass Supreme?
Chuxter is offline
Old February 28th, 2024, 03:14 PM
They are either 194 or 168 bulbs, any good parts store will stock them.
matt69olds is offline
Old February 28th, 2024, 03:53 PM
Matt's correct. FYI, if you own the 1970 CSM there's a page in the electrical section which lists all the bulbs/lamps sizes/part numbers for each application.
Vintage Chief is online now
Old February 28th, 2024, 09:00 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Replace then with LED bulbs and you dash lights will be much brighter.
redoldsman is offline
Old February 29th, 2024, 05:18 AM
Gary
VC455's Avatar
Yes, LEDs give a much brighter outlook, and I went that route too. But be mindful that LEDs will not dim effectively unless you add resistance in the supply wire to the headlight control switch.
VC455 is offline
Old February 29th, 2024, 05:39 AM
Olds Fanatic
69 Hurst's Avatar
I also installed LEDs in mine...the difference is day and night!
69 Hurst is offline
Old February 29th, 2024, 05:44 AM
jaunty75's Avatar
If you have just an owner's manual for the car, bulb specifications will be listed there.
jaunty75 is offline
Old February 29th, 2024, 05:47 AM
joe_padavano is offline
Old February 29th, 2024, 01:27 PM
Dont use a LED bulb in the GEN socket, either the bulb won’t work in the event of a charging system issue, or the charging system won’t power up with the ignition on.
Old February 29th, 2024, 06:20 PM
Chuxter's Avatar
ThNks for the help. I've got the bulb figured out. Is there anywhere to get new sockets?
Chuxter is offline
Old March 1st, 2024, 06:32 AM
You can buy LED bulbs that are not polarized. The real problem is that the factory alternator system requires the resistance of the filament in the incandescent bulb to trigger the voltage regulator.
Old March 1st, 2024, 06:33 AM
Type gm dash lamp sockets into Google
Old March 1st, 2024, 01:30 PM
I did not know that.
Old March 1st, 2024, 07:09 PM
Amazon Amazon
Old March 2nd, 2024, 01:47 PM
Chuxter's Avatar
Related question. Mine is a 1970 cutlass and tge lens for the high beam indicator is gone. Can you get a replacement, can you use some type of cellophane or plastic or would it just be easier to get a colored bulb?
Chuxter is offline
Billyboy746
November 12th, 2022 04:58 AM
fjwhoopie
October 18th, 2021 06:45 PM
w30brad
February 8th, 2020 02:41 AM
nanardos
September 1st, 2013 10:15 AM
Redog
May 23rd, 2011 08:50 PM
Quick Reply: Dash Bulbs
