Electric carb hook up and AC compressor hook up
Old January 7th, 2012, 10:29 PM
projectheaven's Avatar
Hello all,
I'm trying to figure out where do i Hook the positive wire that hooks up to the positive on the carb?
Also, Where does the positive wire from the AC compressor hook up to?
Thank you guys in advance for the help.
projectheaven is offline
Old January 8th, 2012, 09:17 AM
Rickman48's Avatar
Any switched positive wire under the hood will work for the carb - might need a testlight.
Should be a 1"w plastic connector, with 2 wires in it, [green + black?] that plugs into the 2 prongs on the compressor floating around that side of the engine compartment.
Believe it came from the fenderwell and had something else to it that went to the engine.
Rickman48 is offline
MN71W30
February 11th, 2013 07:17 PM
Gearhead442
June 6th, 2012 10:14 AM
jwilly
August 29th, 2011 04:57 PM
ROCKET VAPOR
June 4th, 2010 09:47 AM
68conv455
September 21st, 2009 10:48 AM
Quick Reply: Electric carb hook up and AC compressor hook up
