Engine Harness - Which One ?
Old July 8th, 2008, 11:12 AM
Dr.Olds Illegitimate Son
Maverick's Avatar
Question Engine Harness - Which One ?
I have a 1971 Olds 442 that looks like a dog threw up spaghetti under the hood. Wires everywhere. Most not connected. All from previous owner. WHat harness do I need to clean this up ? Most of it is around the firewall.
Brent
Maverick is offline
Old July 8th, 2008, 01:11 PM
The underhood harness is two major parts, the engine harness and the forward lamp harness. The two harnesses have firewall connectors that fit together into one square connector that mates to the connector on the back of the fuse panel at the firewall. If you remove the center bolt on the firewall connector and pull it away from the firewall, you'll be able to separate the two halves of the connector and thus tell which harness is bad.
joe_padavano is online now
Old July 8th, 2008, 04:40 PM
I think you can get replacement engine and lamp harnesses from Painless wiring. Although, if you take the plugs apart it will let you track those stray wires down. Good luck. I need to do the same.
Olds64 is online now
Old July 16th, 2008, 07:10 PM
68conv455's Avatar
Year One has what you are looking for if you are looking for a simple solution. They have a 71 engine harness set up for a v8 with auto, or, a v8 with manual priced at $109 in my old catalogue. They also have the front light harness if you need that one.
68conv455 is offline
Old July 24th, 2008, 02:20 PM
Registered car nut
nonhog's Avatar
I just bought a harness from OPGI which still had the M&H sticker on the bag .
Shop around !
nonhog is offline
Old July 30th, 2008, 06:35 PM
Chumley's Avatar
I have bought harnesses from M&H with no problems whatsoever. They are EXACT replicas of the originals. They will even do conversions for things like HEI if you want. I give them a thumbs up. Chumley
Chumley is offline
Old July 30th, 2008, 07:51 PM
oldsconv's Avatar
Wiring
Just a point of note - Painless is a very reputable company (I am not criticizing), but from what I have seen, the harnesses are more of an assemble yourself deal with wiring and connectors you can make to custom lengths. I think it is more meant for applications where you might want to customize something. Better when you are making big mods or for hotrods. They may also make exact harnesses as well, not sure. My 2 cents is Look for an exact repro that has all exact wires, colors, lengths and is pre-wrapped and ready to go. I used M & H from CA and also Lectric Limited. Both of these are sold by some of the major parts houses and make exact repros or as close as feasible.
oldsconv is offline
JPMDaddy
January 14th, 2019 08:41 PM
rustycragars
December 25th, 2016 06:06 PM
BlueBlock350
August 1st, 2009 02:24 PM
thomaswatk
March 22nd, 2007 01:31 PM
saxrocks2002
August 18th, 2004 07:06 AM
Quick Reply: Engine Harness - Which One ?
