TH350C pressure switch wiring...does it matter which is + and which is -?
Does it matter which wire I connect to either post on the pressure switch inside my TH350C? Now that I think of it, the posts could be either one depending on how far this thing is screwed in... So since they're not labeled in any way and both connectors fit on either post it must be okay to connect to either one?
That switch should just be a normally open switch that closes under pressure. It doesn't matter which wires go to which terminals - the switch just connects the two wires when it closes.
TH350C Electronics
As the car sat with the front up in the air with no trans pan for 4 months approx.there is the possibility that this may be causing the car to stall out. BTW the car operates normally in Reverse i.e able to sit idling in gear.Thanks in advance
Pull the pressure switch from the valve body. Apply compressed air to the pressure port, I bet you will find countinuity between the 2 terminals. If not, see if either contacts have countinuity to ground with pressure applied. Without a service manual, its difficult to be certain how its suppose to function. Most likely, the solenoid grounds thru the pressure switch. The other terminal might be s signal to the computer that the trans has shifted into 3rd gear. With some compressed air and a volt/ohmmeterit should be pretty simple to figure out.
costpenn
August 29th, 2018 11:42 AM
