Replaced Steering column now not turning over
Old March 31st, 2024, 12:29 PM
Spencer66-442's Avatar
66 442 w/ Column automatic. My steering column had an issue. I removed it, went through it and put it back together.
After re-installing it, blinkers work, horn works, (so ribbon cable is fine) I put it in neutral and she rolls good...put in park holds tight.
There are two other wire connectors that go to the switch assembly (1993659) and I have the tang inserted into the correct slot on the assembly.
But when I try to start it...I get nothing. All other electrical working fine.
The starter was working great when I put it away in November.
Battery with a jump is at 13+ volts...
HELP!
Spencer66-442 is offline
Old March 31st, 2024, 12:43 PM
2blu442's Avatar
I would be sure its in park, then jump the wires across from the neutral safety switch to see if it will start. My guess is you have something out of adjustment on the neutral safety switch and if it starts when bypassed that would confirm it.
2blu442 is offline
Old March 31st, 2024, 02:11 PM
Yes, check the neutral safety switch, the 2 purple wires at the bottom of the column.
oldcutlass is online now
Old March 31st, 2024, 03:00 PM
2blu442... Thank you very much. That did the trick.
Rocket Rob
Suspension & Handling
January 7th, 2023 02:30 PM
Gary's 2 442-S
December 29th, 2021 12:41 PM
dfire25
January 24th, 2013 10:13 AM
4-Speed
September 11th, 2010 08:20 PM
elcaminodave
September 12th, 2008 07:01 AM
Quick Reply: Replaced Steering column now not turning over
