Wire gauge please..
Old April 27th, 2024, 06:45 PM
Tancuda's Avatar
Wire gauge please..
Hi, what would be the original gauge size for the wire that goes from the battery (actually the horn relay) to the "BAT" terminal on the back of a stock alternator (71 442).
Can't see it on the wiring diagram. The one I have if original, is 10 gauge.
Tancuda is offline
Old April 27th, 2024, 07:15 PM
The stock wire according to this, was a 12ga. I would keep the 10ga or even go to an 8ga.
oldcutlass is offline
Old April 27th, 2024, 07:27 PM
72Cutlass S
gs72's Avatar
X2 larger gauge will never hurt. The factory gauged the wire based on amp load and cost per unit.
gs72 is offline
Old April 28th, 2024, 02:56 AM
x3, especially if you're using CCA wire on the cheap.
Olds64 is offline
Old April 28th, 2024, 04:17 AM
Agree w/ everything stated above. I don't have the 1971 CSM in front of me at the moment. NOTE: The 1971 CSM contains a separate B&W wiring diagram for the 4-4-2 model. There are subtle differences between the color A Body "V-8" wiring diagram & the B&W 4-4-2 wiring diagram. The B&W 4-4-2 wiring diagram may well be a 10ga wire.
Vintage Chief is offline
Old April 28th, 2024, 06:24 AM
Tancuda's Avatar
Thanks, I'll be using a good 10ga wire (not CCA).
Tancuda is offline
Old April 28th, 2024, 06:26 AM
Tancuda's Avatar
Would love to have that seperate wiring diagram for 442..
Tancuda is offline
Old April 28th, 2024, 08:02 AM
Purchase an original OEM paperback edition (used) 1971 CSM. Plenty on eBay. You should have this as your bible anyways. Buy an original OEM, not new as new are copies of original and poorly reproduced.
Old April 28th, 2024, 08:06 AM
You said you already had 10ga. The big difference is the ‘71 4-4-2 got an ALT w/ internal VR. Very possible 10ga was OEM but I’m not in front of a 1971 CSM at the moment.
Old April 28th, 2024, 11:42 AM
Tancuda's Avatar
It worked with that 10ga old wire for so many years I believe, going to change it completely with the same gauge.
Tancuda is offline
DeltaLou
March 20th, 2022 08:42 AM
jimcruiser
January 20th, 2021 03:36 PM
sysmg
April 5th, 2019 07:44 AM
yamahondarider
January 16th, 2014 02:32 PM
oldgold
November 19th, 2012 04:58 PM
Quick Reply: Wire gauge please..
