Can anyone decode this data plate?
All i know is the 48 sherwood green It's a 1970 cutlass "S" the car has in it now a 455 e head motor turbo 400 bucket seat auto with a black int
Uploaded with ImageShack.us
ST 70 = style/model year = 1970
33687 = Oldsmobile (3) Cutlass (36) holiday coupe (87)
E = assembly plant = Linden NJ
14166 BDY = body number for that assembly plant
TR 937 = interior color and front seat type = ivory color with strato bucket seats
B80 = option code = exterior drip scalp molding
48 48 PNT = lower and upper body colors = sherwood green for both
06A = time build code = June (06), first week of that month (A), 1970
B84 = option code = exterior body side molding
B85 = option code = exterior belt molding
I'm not exactly sure what the difference is between body side moldings and belt moldings; hopefully, someone else can explain!
Randy C.
Randy C.
Thanks all
Ivory int ?? it's black so it was changed it has a black headliner?
yes it has the wide moulding on the top of the doors and quarter.
what about engine? how do i tell what motor it came with?
re: Engine. Look at the engine stamping pad just in front and below the #1 cylinder. If the last 6 digits of the number there are the last 6 of your VIN, you have the original engine.
The only other way to determine the original engine size would be if you have the original dealer invoices or build sheet. The 70 Cutlass S 33687 could have come with an 8 cylinder engine, but that's all the detail that's provided in the 1970 CSM.
335 = Cutlass L6
Yup, Scott what I meant in my post was whether it was a 350 V8 or 455 V8. Guess I should have been more clear. Too bad they didn't have the coding like the 72.
So the VIN derivative on the stamping pad is going to be his best clue whether it's the original engine for the car
x2248344
August 10th, 2012 04:18 AM
