Epoxy Primer and lacqure Application
Old May 6th, 2011, 04:43 AM
Del70's Avatar
Need some help, share experience in with epoxy primer and lacquer top coat, thanks
1) If I apply Epoxy primer to a fender, bare metal, can I then apply lacquer top coat over the epoxy premier?.
2) If I apply epoxy primer, then primer assumed to lacquer primer to work the panel, can I apply it and then a lacquer top coat?
3) Can Epoxy primer be applied over well cured lacquer.
Del70 is offline
Old May 6th, 2011, 08:10 AM
chequenman's Avatar
Question
Where you gettin' all this lacquer product?? Top quality paint jobs done to-day are done in Water Borne products and Clear Coats.
If you are applying Epoxy Primers don't even think about useing Lacquer primers over top!!! The one primer flexes and the other doesn't.....
chequenman is offline
Old May 6th, 2011, 09:06 AM
Swede98's Avatar
Boat?
Hi I work as a boat mechanic and we use epoxy primer and topcoat on boats but I never heard someone who has used these things on a car I agree with the previous post.
Swede98 is offline
Old May 6th, 2011, 10:38 AM
69442C's Avatar
Here is a PPG Refinish link for their Deltron products and this shows their DP Epoxy primers. Click on any of the TDS tabs next to any of the DP items and you will get the technical data sheet. Their information shows that DP Expoxy primer/sealer can be applied over lacquer finishes with a few precautions. It also shows that lacquer can be applied over the DP epoxy as a top coat.
With this being said, I too would question the desire to do so. Lacquer paints are not widely available and this is not the manner in which quality refinish work is done today. I believe there are some companies who offer Nitrocellulose Lacquer but these finishes don't hold up well and require a lot of maintenance. So unless there is an absolute requirement to use lacquer, I would use a more modern paint system. I think that rattle can paint is still available in lacquer so I would hope you aren't trying to refinish a car with rattle cans?
https://buyat.ppg.com/refinishProduc...c-04551702a5df
69442C is offline
Old May 6th, 2011, 10:40 AM
69442C's Avatar
To clarify, when you go to the link I showed, click on the primers and surfacers tab to get to the DP products.
69442C is offline
Old May 6th, 2011, 10:50 AM
Oldsmaniac's Avatar
I plan on using acrylic lacquer on my 67 442. It is easy to spray and dries very quick. This is great if you must spray outside.... it dries before the bugs can stick to it. It also gives era look. It is forgiving. Most quality high gloss jobs these days do not reflect the finish the car had when it rolled off the assembly line. The drawback is the cost...I believe for PPG lacquer it is 500 dollars a gallon.
Oldsmaniac is online now
Old May 7th, 2011, 06:48 PM
Run to Rund's Avatar
I used PPG DPLF gray primer (epoxy) and the PG guidance is to top coat within a week. I covered some 40 year old lacquer (inside trunk, etc.) with the primer. So the answers are yes, yes, and yes. And, I wanted to use acrylic lacquer with the original luster, not a plastic looking top coat.
Run to Rund is offline
Old May 8th, 2011, 09:27 AM
Swede98's Avatar
Today i learned something
Swede98 is offline
dre
Body work
29
July 31st, 2013 09:37 AM
Nasty455
April 23rd, 2013 01:25 PM
Porter858
September 18th, 2012 08:51 PM
Seriousfun
July 27th, 2012 12:25 PM
Del70
May 6th, 2011 03:54 AM
Quick Reply: Epoxy Primer and lacqure Application
