Exterior door handles
Old June 2nd, 2012, 08:11 AM
Old School Olds
tru-blue 442's Avatar
Does anyone know if the exterior door handels
will interchange between 66-7 and 68-72 on the
A-body? Thanks in advance.
tru-blue 442 is offline
Old June 2nd, 2012, 08:32 AM
kitfoxdave's Avatar
I have no idea if they are but have a similar question! Are 4 door exterior handles interchangeable with 2 doors on 72 cutlass?
Hope the answers come thru to both our questions!
Thanks!
kitfoxdave is offline
Old June 2nd, 2012, 09:17 AM
I always thought they were, since they look identical, but I never actually tried.
MDchanic is offline
Old June 2nd, 2012, 10:48 AM
2blu442's Avatar
The outside looks the same but I believe there's a difference inside the door. I know I've got some with a single pin behind the button, and others with a "T" behind the button. I don't know if the depth is different, but I'll look around to see what I can find to take pictures of.
This is the case on 1970-72 but I'm not sure on the 1966-67 vintage.
John
2blu442 is offline
Old June 2nd, 2012, 10:54 AM
frankr442's Avatar
I installed GM 70-72 Chevelle outside handles on my 71 442. Different part number but compared side by side and saw no difference. I can't look up the # right now, they may still be available, but I did this many years ago.
frankr442 is offline
Old June 2nd, 2012, 11:16 AM
2blu442's Avatar
OK, I've come up with a couple to compare. The 1966 handle has a longer rod behind the button than the 1970. The chrome part looks the same, but I don't know how difficult it would be to swap out the rods.
Back to the 1970-72, it's the back seat on 4 doors and wagons that have a long release rod with a T shape to the end. I'm not sure about the front doors on these car. John
2blu442 is offline
Old June 2nd, 2012, 11:38 AM
Old School Olds
Thanks John. I really appricate you taking time
out to let us all know, Adam.
Old June 2nd, 2012, 01:14 PM
Junkman's Avatar
It is easy to take the button out of the handle. Just rotate the plate that the rod goes through at the back of the handle. If you have to, you can also braze an extension onto the shaft. I take the handles apart to replace the "O" ring that is on the button that cushions it when you let go of the button after opening the door. Most of the time, they are missing, or dried out. This isn't an Olds handle, however, you can see that they are all made alike, except for the outside contour to match the vehicle it is going to be used with.
Junkman is offline
Old June 2nd, 2012, 01:24 PM
kitfoxdave's Avatar
You folks are great! thanks for the help!
HonestDave
June 27th, 2013 07:19 PM
gbrewer
January 29th, 2010 02:46 AM
442_Mustang
Body work
August 17th, 2009 07:28 PM
bcg88
Body work
February 10th, 2009 09:43 PM
Big Joe P
May 23rd, 2007 01:18 AM
Quick Reply: Exterior door handles
