Gas venting issues
Old November 17th, 2012, 02:07 PM
Jetstar 88's Avatar
Gas venting issues
My car decided to puke out some gas today, after a little bit of driving. Something isn't venting right, since it came out from around the gas cap. I had only been driving for ten minutes, and it's about 70 degrees outside right now. I have about 17 gallons in the 21 gallon tank.
Dafuq? Anybody know what the heck could be going on?
Also, the holidays are approaching quickly. I get to use the trunk for it's righteous duty again!
Jetstar 88 is offline
Old November 17th, 2012, 02:12 PM
11.52 @116
jims2000lt's Avatar
It could be that the actual vent for the tank are blocked by something. Usually 2 at the front or sometimes rear of the tank. On the top edge.
jims2000lt is offline
Old November 17th, 2012, 05:14 PM
It could be the actual vent lines are dried, cracked, and leaking.
oldcutlass is offline
Old November 17th, 2012, 05:40 PM
jaunty75's Avatar
Yes, this sound like a classic clogged vent problem. Get under the car and find the gas tank vent tube or tubes and make sure they're open. On my '67 Delta 88, there are two, and they each have about a two-foot length of rubber tubing attached that is routed up above the tank and attached to the body just above the rear axle. This gets the level of the vent opening above the level of the tank so no gas can leak out. The vents are located on the front right corner of the tank on my car.
jaunty75 is offline
19sixty5
Non-Olds Engines
February 10th, 2014 03:35 PM
1954Bob
April 17th, 2013 07:17 PM
ah64pilot
April 9th, 2012 02:55 PM
Texas442
January 30th, 2012 05:36 PM
glord
July 21st, 2009 11:23 PM
Quick Reply: Gas venting issues
