How do I tell if my wheel bearings are bad????
Old September 15th, 2010, 08:45 AM
Wyze's Avatar
It feels like a thump or knock against my floor by the driver side front!!!
I also get alot of it just driving on a straight smooth road!!!
It gets real bad when I let off the gas and just roll or when I'm coming to a stop!!!!
I checked my ball joints a tie rods!!
I also noticed when I had the driver front wheel off the ground I could move the whole thing drum & all!!!!
Thanks Drew!!!!!!
Wyze is offline
Old September 15th, 2010, 08:47 AM
Land Yacht Captain
66ninetyeightls's Avatar
Usually wheel bearings cause a droning or growling sound. It will usually get worse when you load it up by swirving the car left to right. If you can move the whole tire and drum its definatly a sign its loose or not adjusted. Which would lead to failure.
66ninetyeightls is offline
Old September 15th, 2010, 09:12 AM
67442nut's Avatar
What about control arm bushings, mainly uppers?
67442nut is offline
Old September 15th, 2010, 09:14 AM
Wyze's Avatar
This is on my 68 Cutlass with manual drums!!!
Wyze is offline
Old September 15th, 2010, 09:16 AM
Oldsmaniac's Avatar
Check your ball joints again. They can only be checked properly with tension off the coil spring. Jack up car under control arm where spring perch is and use a 2x4 under wheel and tire to check for looseness by lifting up on the 2x4..
Oldsmaniac is online now
Old September 15th, 2010, 09:34 AM
Wyze's Avatar
I'll do that, but when I checked them I had the entire carr off the ground!!!( on a lift)
I grabbed the tire on the top & bottom, push & pulled!!!
Wyze is offline
Old September 15th, 2010, 09:44 AM
Oldsmaniac's Avatar
A lift will not take tension off off front springs. You need a jack under the lower control arm otherwise you cannot accurately check the balljoints because of spring tension.
Old September 15th, 2010, 04:58 PM
Wyze's Avatar
Ok, I went to NTB where a friend works & had a full check!!!!
Both upper & lower need replaced!!!
I let him drive my car and he told me he doesn't think the noise and viabrations are coming the wheel, but from under the car!!!!
Could bad u joints do this!!!
How can I check them????
Thanks Drew
Wyze is offline
Old September 15th, 2010, 08:15 PM
edzolz's Avatar
When you have the car on the ground, engine running, foot on the brake. Shift back and forth between drive and reverse, engine ideling. If you hear a "clunk" as the transmission shifts back and forth, there is a good possibility you have bad U joints. It could also mean rear end gear wear.
edzolz is online now
Old September 16th, 2010, 08:19 AM
Wyze's Avatar
Just did that & hell yeah I've got more than just a clunk!!!
My car bumps hard and moves, everytime I change gear the rearend& driveshaft move also!!!!
Wyze is offline
Old September 16th, 2010, 08:22 AM
Wyze's Avatar
No more racing for a while!!!
Smh!!!
Wyze is offline
odddoylerules
April 21st, 2014 07:54 AM
airmale
November 13th, 2013 11:15 AM
MASH4077
Paint
34
June 27th, 2011 01:23 PM
oldzy
Drivetrain/Differentials
September 14th, 2010 05:40 AM
Andrew240
December 22nd, 2007 01:54 PM
Quick Reply: How do I tell if my wheel bearings are bad????
