Front wheel bearings-- are they the same as GMC FWD motorhome?
Will GMC motorhome bearings fit the Toronado knuckles? Supposedly the only modification made to the Toro knuckle to fit onto a motorhome is to ream out the lower ball joint bore to accept the larger motorhome ball joint. There is no mention on if this is the big bearing that is used on the early knuckles, or the smaller bearing used on later Toronados. Perhaps someone who is more in the know than myself can tell. The OD on the bearing is 3.250". I do not have an early and late knuckle to measure to see what the difference is.
Here is what I found at http://www.appliedgmc.com:
Timken #LM104949e 904A2
Last edited by Andrew240; December 22nd, 2007 at 03:29 AM. Reason: Added part number
Toro Front Wheel Bearings
Hi Andrew
I'm not a Toro expert by any means but I thought the front wheel bearings were more like CV joints as the new front wheel drive cars are. Attached is a photo of a drive axle I removed from a 1969 Toro and I thought the 66-67 used the same setup. John
New front wheel drive cars have the wheel bearings/hub sold as a unit, and are typically held into the knuckle by a few bolts.
The Toronado CV shaft passes through the knuckle. The hole that is passes through is the ID of the wheel bearing. Here is a picture of the back of a spare knuckle that I have. You can see the toothed part of the CV shaft passes all the way through the knuckle to the toothed inside hub.
5998DownUnder
Ninety-Eight
June 29th, 2013 09:45 PM
deltathunder
April 22nd, 2012 09:36 AM
56Super88
August 21st, 2011 05:59 PM
