why Olds motor in 1975 GMC motorhome ?
Old January 7th, 2013, 10:43 AM
VikingBlue's Avatar
http://newjersey.craigslist.org/rvs/3519470972.html
Research these a little and they came with an Olds 455. Why not a factory Chevy motor ?
VikingBlue is offline
Old January 7th, 2013, 11:02 AM
Lansing built
1970cs's Avatar
Reading some articles it looks like they used the Toronado drive train, to lower the over all height of the motorhome, (no drive shaft) lower center of gravity and easier step in height.
Pat
1970cs is offline
Old January 7th, 2013, 11:04 AM
Collector of Stray 55's
Olds Dad's Avatar
Because they're front wheel drive and Olds was already set up for the FWD with the Toro drivetrain.
Pretty cool units - always wished I had the place for one - neat resto project
Olds Dad is offline
Old January 7th, 2013, 11:29 AM
Because the TH425 transmission used in those motorhomes only came with a BOP bolt pattern bellhousing. The two engine choices that were EPA certified with that trans were the Olds 455 or the Caddy 500. I'm guessing that Caddy didn't have the production capability to support GMC production.
joe_padavano is offline
Old January 7th, 2013, 11:40 AM
"me somebody" site member
aliensatemybuick's Avatar
Wasn't FWD required as well by the Department of Defense?
aliensatemybuick is offline
Old January 7th, 2013, 12:03 PM
Only if it came with 'Stripes'...and was designated EM-50 Urban Assault Vehicle
Allan R is offline
Old January 10th, 2013, 08:23 PM
oregontopcat's Avatar
GMC motorhome
I have had a number of these come through the shop over the years. One interesting tidbit is that to replace the engine you were supposed to construct an overhead track which started above the engine entended rearward then exited out the door. you used a chain hoist and trolley to lift the engine then transport it out the door. Complete instructions were in the factory service manual including where to set the the support legs. Quite a process!!
oregontopcat is offline
Old January 12th, 2013, 07:15 AM
Rocket331's Avatar
Always wanted one!
The closest I ever got to owning one was our 1945 Flxible equipped with a '68 455 and THM400. It hauled the old bus along very well, much better than the original straight 8 Buick, except it would frequently overheat.
Rocket331 is offline
deltathunder
April 22nd, 2012 09:36 AM
starr88
March 3rd, 2012 02:03 PM
56Super88
August 21st, 2011 05:59 PM
Van Dashner
July 5th, 2008 11:32 PM
Andrew240
December 22nd, 2007 01:54 PM
Quick Reply: why Olds motor in 1975 GMC motorhome ?
