How to remove window channels
Old June 6th, 2012, 05:08 PM
bluecutlassconv's Avatar
I have a 1969 olds cutlass s convertible. I want to replace the window channels. Do I to remove the windows to do this?
bluecutlassconv is offline
Old June 6th, 2012, 09:09 PM
70Post's Avatar
Are you referring to the window sweepers/fuzzies that mount at the top of the outside door skin and press against the outside of the glass?
If so, NO, you don't need to remove the glass. You'll need to remove the door panels and loosen the window "stop" pucks/blocks that prevent the window from going lower inside the door. Once you lower/loosen/or remove those lower window stops you can crank the window down low enough inside the door shell to get a straight shot at all the phillips head screws that hold the sweepers on.
70Post is offline
Old June 7th, 2012, 05:55 AM
Yes thats what I am talking about, thanks.
RandyS
July 12th, 2012 02:55 PM
dennisspeaks
October 3rd, 2011 09:23 PM
eodette
November 17th, 2010 06:53 AM
1964F85
April 7th, 2010 07:46 AM
mike14_07
Body work
July 14th, 2009 12:55 PM
Quick Reply: How to remove window channels
