olds 330 fuel difference in octane
330 LC 2 barrel. Has been running from the original owner for eyars with 87-89. Do you think if I fill it after she gets close to E with 93-94 it will make a big difference, what could I expect. Thanks for you insight.
Since it's a low compression motor, it should run on regular if properly set up and tuned.
Maybe not 87-regular, but certainly 89-regular. I can't see a reason to run it on more than 91, even if you want a margin of "safety."
Remember, these engines were not spec'ed to run retarded from the factory - they were supposed to run with a correct amount of advance, so advancing it more and using premium probably won't get you much , if anything.
navvet
August 26th, 2013 07:06 PM
