Paint removal
Old December 29th, 2015, 04:06 AM
rand5204's Avatar
Paint removal
I recently acquired a set of nice used (not repop) 70 442 grilles. The only problem is that somewhere along the line someone painted them gloss black with what must have been a rattle can. Some of the paint is flaking off but how do I get it all off without ruining the original finish?
Thanks for any help
rand5204 is offline
Old December 29th, 2015, 04:52 AM
toymobile's Avatar
Brake fluid ??? Test a spot unseen to see if the original finish is affected, water will desolve the fluid. have a hose on the ready. Good luck
Johnny
toymobile is offline
Old December 29th, 2015, 05:44 AM
RROLDSX's Avatar
I would try a paint remover on a test spot and see how that works. You will likely have to sand everything anyway and re-paint so it might be feasible to just sand smooth the existing paint and refinish. My non-professional opinion.
RROLDSX is offline
Old December 29th, 2015, 06:30 AM
edzolz's Avatar
I have had good luck removing paint using oven cleaner. It is mostly lye in a sprayable can. It should not attack the plastic. Spray it on, leave it on 8 to 12 hours and wash with a high pressure water.
edzolz is offline
Old December 30th, 2015, 03:51 AM
rand5204's Avatar
Thanks all for the great suggestions. Hopefully something will work without damaging the parts.
rand5204 is offline
Old December 30th, 2015, 08:22 AM
4speed455's Avatar
After you strip the paint you can use krylon dull aluminum spray paint to reproduce the original color. It's a dead on match.
4speed455 is offline
Old December 31st, 2015, 12:27 PM
marxjunk's Avatar
they make a spray bomb can with rubber/plastic stripper in it. You have to get it from a paint supplier..
its slow as heck..but the secret is to lay a piece of plastic down put the grill in the center spray it...and wrap the plastic all around it to seal it..it keeps the chemicals "hot"..its pretty mild but will burn skin...works best at 70-80 degrees
marxjunk is offline
DewChugr
July 15th, 2015 08:52 PM
dfire25
December 5th, 2012 12:23 PM
Tom442
June 21st, 2011 05:30 AM
therobski
Body work
February 20th, 2010 08:27 PM
68Tom
Paint
July 3rd, 2009 05:12 PM
Quick Reply: Paint removal
