Pal/Speed nuts or Barrel nuts for emblems on 68 442
Old July 25th, 2011, 08:53 AM
Tom442's Avatar
I see them called PAL nuts or Speed nuts, or would Barrel nuts be a better choice for the 442 on fenders and deck lid? I kind of like the idea (had them on an old mustang) of the barrel nuts as it was easy to remove emblems and detail these areas...Opinions?
Tom 68 442 (LIVE...LIVE!)
70 F85
95 Aurora
skateboard
Tom442 is offline
Old July 25th, 2011, 09:03 AM
Rickman48's Avatar
Bad thing about the barrel nuts is they can chip the paint, causing rust!
Someone used to make 'speed nuts' with rubber washers, but haven't seen those in 30 years! They would seal the hole, from the back.
Detail with Q-tips!
Rickman48 is offline
Old July 25th, 2011, 10:22 AM
allyolds68's Avatar
You can't get to the fender emblems once the fender is on the car so barrel nuts won't help much. If you spin the deck lid nuts off the rear trunk trim more than about twice you'll break the studs off. (those came with barrel nuts from the factory anyway)
I just found a bunch of them when I was putting my car back together. I'm pretty sure they were used in specific places but I didn't take the car apart so I couldn't tell you where that was.
allyolds68 is offline
Old July 25th, 2011, 11:07 AM
Tom442's Avatar
I did find some Pal/Speed nuts with sealer, I like that plan better. You are right about the Barrel nuts...the did chip up the paint on my mustang.
first image Pal/Speed nut
second Barrel nut
third Acorn nut...from my family tree
File Type: gif
Tom442 is offline
Old July 25th, 2011, 12:24 PM
69442C's Avatar
second Barrel nut
Just as an FYI, the speed nuts used for emblems were a little different than this one. This particular nut is used with a threaded stud like a T-Bolt that is used to attach the front fender moldings. This style nut will not cut threads on it's own like the nut used for the emblems. The way to tell is this style only has one notch in it so its made to work on a threaded stud. The style that will cut threads will have 2 notches and they will be a little larger notch than you see here.
69442C is offline
Old July 25th, 2011, 12:59 PM
TripDeuces's Avatar
http://www.thefastenerwarehouse.com/...age/584919.htm
Here's one source.
TripDeuces is offline
Old July 25th, 2011, 02:28 PM
Originally Posted by TripDeuces
Trip - that's a great link. Added it to my favorites. Thanks much!
Allan R is offline
Old July 25th, 2011, 02:46 PM
Tom442's Avatar
Thanks for the info on my nuts. Two cuts and not one. Do ya think it might be a good idea to put some sealer in the nuts like 3-M rope caulk? nahh, not like it will be soaking anywhere I hope. Awesome link Trip Duece! Thanks everyone.
Tom
Tom442 is offline
Beau Dirt
December 27th, 2021 03:02 PM
442much
November 22nd, 2018 06:17 PM
63 F85 Cutlass
February 8th, 2015 03:20 PM
66ninetyeightls
March 28th, 2010 07:40 AM
4EYED
September 22nd, 2007 10:33 PM
Quick Reply: Pal/Speed nuts or Barrel nuts for emblems on 68 442
