Removing Barrel Nuts 72 Cutlass Trunk Emblems
Old August 25th, 2007, 11:16 PM
4EYED's Avatar
I picked up a 72 Cutlass Supreme recently. The previous owner got a nicer trunk lid at a swap meet and had it on the car when I bought it. It is currently in primer and we had planned to paint it tomorrow. My question is.. How in the world do you get those darn "OLDSMOBILE" letters off? From reading up, the little green things are called barrel nuts but I'd hardly consider them nuts... they look more like some sort of locking sleeve. There's gotta be a trick somehow because they had them off when they shot the primer on the lid because there's no paint on them and primer behind them. I hope they didn't just shove them back in the holes and use super glue. I don't think anyone would be that dumb knowing the trunk would be painted eventually and they'd have to come back off, but I don't put anything past anyone anymore.
Any help would be greatly appreciated!
4EYED is offline
Old August 26th, 2007, 07:05 AM
2blu442's Avatar
They may not be barrel nuts but something I've heard called speed nuts. It still should take a 6 point socket to remove. I've got some in the garage, I'll try to take a photo of what I'm thinking it might be. John
2blu442 is offline
Old August 26th, 2007, 07:49 AM
2blu442's Avatar
OK, if they don't look like barrel nuts do they look like this? That's the two kinds of fasteners I'm used to on emblems and trim. John
http://i90.photobucket.com/albums/k2...2/P1010734.jpg
2blu442 is offline
Old August 26th, 2007, 01:10 PM
Barrel "nuts" are simply small sleeves made of spring steel and are designed for use in blind installations where it isn't possible to get to the backside to install a speed nut:
http://www.oemhardware.ca/oempdf/BSS.pdf
There are barbs on the outside that snap into the hole in the sheet metal and barbs on the inside that grip the post on the trim.
Barrel nuts are designed to be replaced. Gently pry under the trim to remove it. Pull the old barrel nuts out of the holes. Buy new ones to reinstall the trim.
Most automotive body and paint stores sell these items.
joe_padavano is offline
Old August 26th, 2007, 01:13 PM
More on barrel nuts
Turns out Dorman Products sells a range of barrel nuts - also called tubular nuts:
https://www.dormanproducts.com/cgi-b...58330&item_no=
Old August 26th, 2007, 05:18 PM
Past Administrator
Oldsguy's Avatar
good info Joe, as usual.
Oldsguy is offline
Old August 26th, 2007, 08:26 PM
4EYED's Avatar
Those are the ones, Joe! I pried on the letters gently and they slid right out. Thanks again and I'm so thankful I found such a great forum. This is my first resto project and I'm sure I will learn a lot from this group.
4EYED is offline
Old September 22nd, 2007, 10:33 PM
72rocket's Avatar
I found some for 1/8" studs (for trunk letters) at the local Pep Boys. Called tubular nuts (package said Body-Tite , Dorman on back), found em' in the "Help" section. They have a bunch of other sizes too. Only thing that sucks is they only came in a package of 3 so I cleaned them out of course. Hope they order more.
72rocket is offline
BlueCalais79
March 7th, 2015 04:42 AM
63 F85 Cutlass
February 8th, 2015 03:20 PM
Tom442
July 25th, 2011 02:46 PM
1968Cutlassfallbrook
April 14th, 2011 02:38 AM
HouTXCutlass
Body work
March 2nd, 2009 04:42 PM
Quick Reply: Removing Barrel Nuts 72 Cutlass Trunk Emblems
