what car did my motor originally come from
Old June 1st, 2012, 09:39 AM
jchavis44's Avatar
Exclamation what car did my motor originally come from
trying to find out exactly wat car my motor came out of
vin #358695C133014
casting #395558
intake #411990
head (8) # 411929
metallic blue engine which suggest its somewhere between a 75 - 76
i cant see the derivative # because there's a plate blocking it or isn't there at all (i've tried lookin numerouse times)
its currently in a 1965 delta 88 celebrity sedan
jchavis44 is offline
Old June 1st, 2012, 09:47 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
395558= 68-70 350
#8 heads are smoggers off a 73-76 SBO
Not sure about the the vin. Where did you get that #? Not off the pad. The pad should contain 9 characters and the first two should be numbers then a letter. The last 6 are the vin off the car it originally came from. Get a mirror out and read it from under the car if the power steering brackets in the way which it usually is.
droldsmorland is offline
Old June 1st, 2012, 10:00 AM
jchavis44's Avatar
And it is in the way...damn ..and thats the vin off of my car.....looks like i have to get dirtier then i was hoping....
Old June 1st, 2012, 10:26 AM
jchavis44's Avatar
Found it 35R148827 derivative #
Old June 1st, 2012, 11:48 AM
So it's a 1975 350, as we thought ('73 to '76).
MDchanic is offline
Old June 1st, 2012, 12:22 PM
jchavis44's Avatar
Yessir.. can u telll me which car it came from or which model
3= olds
5= 1975
R= Arlington TX
the rest is original car's sequential production number.
Also the 395558 is an ID code 5 block which would indicate 73-74 350 SBO. (The code 2 395558 is a 68-70 350SMO)
Your engine most likely was out of a 75 model year cutlass or Delta 88 as Arlington made both
Old June 1st, 2012, 12:32 PM
jchavis44's Avatar
Is there anyway to track down the car using last 6 vin #'s
Old June 1st, 2012, 01:06 PM
jchavis44's Avatar
Thanks thats so helpful
Old June 1st, 2012, 01:35 PM
Nope. None at all.
It's a 350 from a '75 Olds. That's the best you're gonna be able to do.
MDchanic is offline
Old June 1st, 2012, 01:59 PM
jchavis44's Avatar
Just left advanced auto and 75 delta looks lije the rite parts
1974 Cutlass
March 11th, 2024 06:19 AM
dewcrazzy
March 2nd, 2013 08:45 AM
70 cutlass s
January 1st, 2010 06:19 PM
Modern Motoring
December 30th, 2007 01:57 PM
Huron
July 10th, 2007 08:35 AM
Quick Reply: what car did my motor originally come from
