What do the experts think about this engine.
Old October 20th, 2021, 01:18 PM
ericisback's Avatar
Would appreciate any feedback you might have about this engine. Thanks for any help:
ericisback is offline
Old October 20th, 2021, 01:29 PM
Rallye469's Avatar
What's that weird mold line box around the "F" on the head?
Looks like the way experimental pieces were done, right?
-peter
Rallye469 is offline
Old October 20th, 2021, 02:43 PM
Oldsmaniac's Avatar
The blue engine paint maybe a bit light, looks like 66=67 Tornado blue...
Oldsmaniac is online now
Old October 20th, 2021, 03:05 PM
Old School Olds
tru-blue 442's Avatar
That F looks a little like the ones Chris Witt used to fab up.
tru-blue 442 is offline
Old October 20th, 2021, 05:32 PM
71 cutlass convertible
lshlsh2's Avatar
Looks nice but there is a lot of important stuff inside that we don't know anything about.
lshlsh2 is online now
Old October 20th, 2021, 06:29 PM
70W-32's Avatar
Oil fill cap should be shiny, not painted. Altenator is not open face. Why go to all the detail and not connect the washer fluid hose to the cap. No stickers on the air filter lower housing or Oil fill tube
70W-32 is online now
Old October 20th, 2021, 06:45 PM
Loaded68W34's Avatar
A few other small nit-pick items: upper radiator hose and bypass hose have chevy style clamps (should look like the clamp visible on the lower radiator hose). As far as I know, the wire going from the battery to the horn relay should be on its own, not wrapped in the alt/ engine harness. It also looks like it may have a drum brake master cylinder, but also has the disc brake valve below it. Over all though it does look very presentable. Agree that is does look like toro engine blue.
Loaded68W34 is offline
Old October 20th, 2021, 06:54 PM
Phantom Phixer
Charlie Jones's Avatar
Positive battery cable is " spring ring " .
Negative is conventional clamp .
At least it doesn't have any " quickie repair " terminals .
Charlie Jones is offline
Old October 20th, 2021, 06:58 PM
4speed455's Avatar
When I replaced my battery cables I was told that is correct for 1970 big block cars. Even though it’s not correct I ordered a small block negative cable so they would match.
4speed455 is online now
Old October 20th, 2021, 07:11 PM
v8al's Avatar
Aren't those battery cables correct for a 1970 442?
And obviously they are reproduction inner fender wells.
Hood hinges and springs are incorrectly painted.
Are the double threaded head studs right for this car? Shouldn't this just be under the heat shroud?
v8al is offline
Old October 20th, 2021, 07:24 PM
Old School Olds
That bolt would be in the correct spot for an A/C bracket.
Old October 20th, 2021, 07:45 PM
v8al's Avatar
Yes - correct location for AC bracket. And on drivers side a similar bolt is in place for a drivers side mounted alternator bracket which this car does not have.
So my question is were these bolts installed on all engines regardless if the accessory brackets would be there or not?
v8al is offline
Old October 21st, 2021, 02:57 AM
ericisback's Avatar
Thanks to all for the feedback - very helpful.
Old October 21st, 2021, 05:37 AM
I moved your threads to the General forum. Let us know if you buy one of those cars.
Olds64 is offline
Old October 21st, 2021, 06:20 AM
ericisback's Avatar
Thank you.
cutlassowner79
September 14th, 2021 07:41 PM
J1978
June 25th, 2021 04:26 PM
DrOldsMN
Care and Appearance
August 17th, 2019 01:32 PM
1968CutlassSupreme
October 23rd, 2014 12:40 PM
420weblazeit
April 7th, 2014 10:12 AM
Quick Reply: What do the experts think about this engine.
