1970 Cutlass Charcoal Fuel Canister
Old August 20th, 2010, 11:40 AM
1970 Cutlass Convertible
frasco's Avatar
Can anyone confirm if a 1970 Cutlass Convertible came with a charcoal fuel canister? I am asking because mine does not have one.
frasco is offline
Old August 20th, 2010, 01:24 PM
Some did, some didn't. Calif cars got them in 1970. Other states got them in 1971.
joe_padavano is online now
Old August 1st, 2011, 06:29 PM
nj_cutlass72's Avatar
not to revive an old post from dead, what is the purpose of the canister and how often do they require a replacement?
nj_cutlass72 is offline
Old August 1st, 2011, 06:40 PM
It holds gasoline vapor for the engine to suck out and burn when it's running.
As far as I know, they last forever, but I'm sure someone else will know more accurately.
MDchanic is offline
Old August 1st, 2011, 06:44 PM
ah64pilot's Avatar
If anyone needs one for the cost of shipping it's yours
ah64pilot is offline
Old August 1st, 2011, 07:50 PM
cutlass47's Avatar
Charcoal Canister
In what condition is the bracket that holds the canister? Mine on my 1972 Supreme (350 ci with 4bbl) has several rust holes and my mechanic lost the odd screw that tightens the bracket around the canister when he tried to remove the canister for the first time since my car was new. I finally removed it myself after a lot of pulling and straining!! I would like to keep mine original and paint it and the bracket as well, but would like to find a bracket in better shape than mine and hopefully with that odd screw. Also, do you know if your canister is original to your car with the two nipples to connect to the two rubber vacuum hoses? I have seen later ones with different configurations.
cutlass47 is offline
Old August 1st, 2011, 09:25 PM
ah64pilot's Avatar
Just took some pictures for you...pm me an email address and well exchange addresses if you want it. If you decide you want it, I'll send them to you...you can send back a check for shipping. Honor system works for me.
rhett838
July 24th, 2015 12:23 AM
oldzy
July 1st, 2013 06:55 PM
jbestic
March 26th, 2012 08:02 PM
texasred
May 14th, 2011 06:04 AM
esisson
November 23rd, 2008 10:05 AM
Quick Reply: 1970 Cutlass Charcoal Fuel Canister
