Oil rated hose vs fuel rated hose
Old March 15th, 2015, 06:14 PM
Sampson's Avatar
Today coming home from a great day of cruising I blew a transmission cooler line. What a mess. Oil everywhere. I mistakenly used a piece of 5/16th fuel hose on the transmission cooler. Well not really mistakenly. I thought that if it was rated for fuel it would be oil resistant. Wrong! I am sharing this in the hope that my lesson will prevent this from happening to someone else. Here is a very nice article on the subject.
http://www.motor.com/article.asp?article_ID=1580
So what is the best way to remove oily residue from virtually every component on the right side of the car from the front to the rear?
Sampson is offline
Old March 15th, 2015, 06:42 PM
Wow. I've used fuel line hose for that before with no problems.
Live and learn, huh?
Thanks.
MDchanic is offline
Old March 15th, 2015, 06:45 PM
steverw's Avatar
Bummer dude, The self serve get out and spray it yourself carwashes here, have a mode for engine degreaser. You might try that if you have them in your area.
Steve
steverw is offline
Old March 15th, 2015, 08:06 PM
morgan
pogo69's Avatar
That does sound like mess i'm not sure why a gas hose would fail with oil...maybe there is a rubber expert here
And thinking more hydraulic hose is rated for pressure and temp. But your trans shouldnt get that extreme...interesting
pogo69 is offline
Old March 15th, 2015, 08:29 PM
The nastiest is the rubber lines rated for brake fluid.
Koda is offline
Old March 15th, 2015, 11:30 PM
Rocket Renegade!
Thanks for posting your experience. Something else to worry about ...
BangScreech4-4-2 is online now
Old March 16th, 2015, 01:09 AM
Yellowstatue's Avatar
A friend had the same issue with his miniature Kenworth/pick-up. Blew the fuel hose splice on his tranny on a short cruise around town. Regular (old type) fuel hose is for low pressure application and the tranny cooler line pressure is much higher, so he blew the fuel hose.
Yellowstatue is offline
Old March 16th, 2015, 02:56 AM
'87 Delta 88 Royale
rustyroger's Avatar
And thinking more hydraulic hose is rated for pressure and temp. But your trans shouldn't get that extreme...interesting
Surely that was outlined in the attached article.
Different lubricating oils have different chemical properties, and fuels do too. So the manufacturers make hoses to suit the applications they will be used for.
If a spokesman for Gates or Dayco says they can't make a "One size fits all" hose, I'm inclined to believe them.
Roger.
rustyroger is offline
Old March 16th, 2015, 06:02 AM
cherokeepeople's Avatar
yup.ever see a car with a blown oil cooler in the radiator.all the coolant hoses will swell,turn to mush and have a sticky feel to em.as for the hoses they are usually clearly marked fuel,trans etc.
cherokeepeople is offline
Old March 16th, 2015, 06:50 AM
I use hyd hose for my coolant lines from the transmission to the radiator routed over the wheel well. Been on there a few years now with no issues.
oldcutlass is online now
Old March 16th, 2015, 06:56 AM
morgan
pogo69's Avatar
Roger.
I Didnt notice the article link in the first post untill after i posted
pogo69 is offline
Old March 16th, 2015, 07:21 AM
mrolds69's Avatar
The article is interesting, thanks for posting. Most of this I already knew. What I didn't know was about the in tank pump hose. I've never done an in tank pump, but that's interesting and a bit crazy they can't make hose that works in + out!
mrolds69 is offline
Old March 17th, 2015, 05:47 PM
67442nut's Avatar
Ditto.
Also, transmission fluid has detergents that probably shorten the life of hose that's not for that specific application.
67442nut is offline
Old March 21st, 2015, 05:02 PM
Sampson's Avatar
Here is a pic of the blown hose. There is a couple mm slit. I believe the failure is pressure rated. The hose is rated J302.7.
[IMG][/IMG]
Here is the correct hose.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I bought this through Car Quest.
I guess all 5/16th rubber hose is not created equal. I hope this info will spare someone else some frustration.
Sampson is offline
Old March 24th, 2015, 08:43 AM
CutlassDad's Avatar
Time to take short lengths of the various hoses in my "hose" bin and treat them to a summer soak in today's fuel.
CutlassDad is offline
Old March 24th, 2015, 09:33 AM
bccan's Avatar
IIRC "Not For Fuel Injection" hose is rated appx 40psi
bccan is offline
Vandy
November 5th, 2014 11:02 PM
Goliardi
Wheels and Tires
February 18th, 2014 08:06 PM
Rob delta
September 17th, 2012 08:56 PM
Scottem
June 22nd, 2009 01:48 PM
Quick Reply: Oil rated hose vs fuel rated hose
