70 CS hazard flasher knob and E-brake release lever
70 CS hazard flasher **** and E-brake release lever
Hey there.
Already posted to the noob section, but I think heres the right place:
I have two questions regarding E-brake release lever and hazard flasher **** - both of which are missing in my 70 cutlass supreme...
Brake release lever (image #1):
* Is this a GM screw-on T-handle or is it molded to the metal rod?
All I can see is a rest of plastic and some epoxy. Screw-on handles are available here in Germany, but I'd have to order the complete assembly with rod in the US.
Hazard flasher **** (image #2 nd #3):
Mine is missing. There seem to exist two different GM versions:
A) the chrome ones that are screwed in directly
B) the pastic one that has a little nose - apparently to fix it in a position where the text can be read - and seems to be fastened with a center screw.
* Does my steering column look as if only the **** is missing or is something broken?
* What size of thread is that center screw?
* Which one was originally used in my 70 CS?
The black plastic seems right, the little nose looks like it's a perfect match.
Thanks!
Thanks!
Last edited by Nop; November 10th, 2013 at 01:01 AM. Reason: Darn typos. It's noob, not boob...
As for the brake release handle:
It arrived today but I was too much of a ***** to press it on - I thought it might crack because of the tight fit.
Tapped an European "M6" thread onto the splined rod and into the plastic handle (you see the tight fit it would have been without thread) and screwed it on. Bingo.
Still waiting for my hazard flasher **** though...
